iron removal method question
Discussion in 'Water Softener Forum, Questions and Answers' started by curt21, Aug 30, 2012.
  1. curt21
    curt21 New Member
    Jul 20, 2012
    Newfoundland
    As it turns out my well water is loaded with iron beyond the capacity of a water softener resulting in stained fixtures, odor etc.. I have been told there is an easy solution for the iron removal but wanted to check here first: install a simple inline chlorine dispenser ( i assume similar to those used for spas/pools) in the T joint before my pressure tank. This allows the pressure tank (along with extra pipe coil if necessary) to be used as contact tank. After the pressure tank a basic sand filter with backwash as purchased from a pool shop is installed to filter out the now precipated iron particles. What do you all think? I've done some research and I think I may give it a try...I realize there are other options but can you see this one working?
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    I think...................I think, let me get this right. You want to use an inline chlorine dispenser like used for hot tubs to inject the chlorine.? Those things are ok for killing bugs in a hot tub but nowhere near as accurate as an injector pump made for water conditioning so.........get one of those instead, pellet or liquid, either will work. Using the bladder tank for precip is IMO a bad idea because the chlorine will cause the bladder to fail prematurely and what do you do with all that iron that precipitates in your tank? It needs a place to drain. Before you get much further, take a water test for iron and let us know the results.
  4. Mikey
    Nov 8, 2005
    Consumer
    Hansville, Washington
    There are so many problems with that proposal I'm not sure where to start, but getting the water tested is ALWAYS a good way to start -- getting rid of a LOT of iron is a different problem than getting rid of a little. One specific thing: my bladder tank manufacturer recommends chlorinating before the pressure tank, but AFTER mixing in a contact tank. However, I think the majority of folks in the trade will recommend keeping chlorine out of the bladder tank.
Similar Threads: iron removal
Water Softener Forum, Questions and Answers Advice for replacing a water softener for iron removal Feb 19, 2017
Water Softener Forum, Questions and Answers Sulfate and Iron removal Nov 2, 2016
Water Softener Forum, Questions and Answers Iron removal Jul 25, 2016
Water Softener Forum, Questions and Answers Iron Breaker III vs KDF 85 for Iron removal Dec 31, 2015
Water Softener Forum, Questions and Answers Irrigation Well Iron removal system recommendations ***UPDATE*** Sep 10, 2015
