Iron pump on hot water loop?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dwi, Jul 30, 2013.
  1. dwi
    dwi New Member
    Jul 30, 2013
    south west MO.
    Hi,
    In my maintenance job I came across a small B&G circulating pump installed on a hot water loop in a 60+ room Motel. It isn't very old, less than a year. I found the box that it came in indicating it is an iron cast not brass. What problems should I be aware of to report to the owner? I'm sure the cost difference was
    the reason this happened.
  2. jadnashua
    Code requires it to be SS or bronze as I understand it. Because potable water has lots of dissolved oxygen, it will eat itself up fairly quickly, not counting the iron it adds to the water for potential stains on the sinks and showers. An iron pump is only okay in heating situations where it is a closed system - there, the oxygen gets purged fairly quickly and the water becomes somewhat inert.
  4. dwi
    dwi New Member
    Jul 30, 2013
    south west MO.
    Are there any potential health problems connected with this sort of thing? Wouldn't the rust build up in the water heaters over time?
  5. hj
    There aren't any "health problems" unless someone starts drinking the hot water. The pump will rust and deteriorate fairly rapidly because of the oxygen in fresh water. Cost and lack of knowledge, are the two most common reasons. the "rust" will occur ON the pump and will stay there until the pump fails.
  6. jadnashua
    The rust particles could flow through the pipes and clog faucets and/or showerheads. Because it is being distributed to lots of places, the amount would be small at any one place, and it may not be noticeable. The 'proper' pump costs more, but maybe not when you consider that the iron one will need to be replaced sooner and could create some other issues along the way.
  7. hj
    If the particles detach from the pump, and they usually do not, they will go into the storage tank and fall to the bottom. The quantity would be very small so they would not "fill up" anything, nor would they gravitate to the faucets.
  8. dwi
    dwi New Member
    Jul 30, 2013
    south west MO.
    Thank you both for your help. I may not get them to change it right now but they may just change it soon enough.
    dwi
  9. hj
    Let it run until it freezes up or deteriorates to the point it no longer circulates.
Similar Threads: Iron pump
Plumbing Forum, Professional & DIY Advice Hard buildup in cast iron drain pipe Saturday at 9:10 PM
Plumbing Forum, Professional & DIY Advice How do I tell if the Soil Pipe is Cast Iron or Steel? Mar 17, 2017
Plumbing Forum, Professional & DIY Advice PVC to Cast Iron for toilet drain Mar 12, 2017
Plumbing Forum, Professional & DIY Advice Chinese cast iron no hub vs Charlotte Mar 11, 2017
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Feb 21, 2017
