I am in need of a iron removal filter system for a private well.
I plan on using the following components from Ohio Pure Water and piece together a system. Any feedback is appreciated.
-12x48 Inch Fiberglass Mineral Tank w/Base
-Fleck 7000SXT 1-1/4 Inch Auto Backwash Filter (Carbon, Birm, Multi-Media, Sediment & Calcite) System Electronic Control Valve
Tank Diameter: 12 inch tank diameter
Tank Height: 48 inch tank height
Valve to be used: for Iron Filter
Valve connection: 1 Inch NPT PVC
Bypass Valve: Add Bypass Valve
- 32mm Standard Mesh Basket Riser for Fleck 7000 Valves Only (BD32MM + DT32MM-72)
- Fleck 7000 Valve - Only, 32mm Bayonet Style Top Basket, Standard Mesh Resin, TDB32MM-BS (FL40697-02)
- Garnet Support Bed (16 pounds) (Gravel bed)
- 2 CuFt Katalox Light media (from US Water Systems)
Is there anything that I may be missing?
Thank you.
Thank you.
