Iron and low Ph problem
Discussion in 'Water Softener Forum, Questions and Answers' started by Kendallroad, Jul 9, 2012.
  1. Kendallroad
    Kendallroad New Member
    Sep 16, 2007
    I woul like to replace my calcite neutralization system with a solution based injection system.
    I would like to use a water controled dosing pump using a soda ash and hydrogen peroxide solution to cure my soluble iron and low Ph problems.
    Any information as to the as to the type pump to use.
    My well pump has a output in the 10-15 gpm range
  2. Gary Slusser
    I wouldn't do that, solution feeders can be difficult to live with and especially when you use one attempting to treat two different problems.
  4. ditttohead
    Jan 9, 2012
    Ontario California
  5. bcpumpguy
    bcpumpguy New Member
    Jul 27, 2012
    Langley BC
    how about using an lmi, stenner, or seko injection pump with water meter you could use the water meter to hook up to one pump and have the other inject of the first pump. I would use soda ash and chlorine then you'll need a contact tank and a birm or nextsand filter.
Similar Threads: Iron problem
Water Softener Forum, Questions and Answers Filter recommendation for apparent iron problem Mar 4, 2014
Water Softener Forum, Questions and Answers Problem History & Questions About Iron Filter/Softener Setup May 23, 2013
Water Softener Forum, Questions and Answers Iron, H2S, and other Problems with Existing Well Water Treatment System Oct 14, 2012
Water Softener Forum, Questions and Answers Autotrol Iron Filter Problem Jun 15, 2012
Water Softener Forum, Questions and Answers Iron problem, well chemistry changing? Dec 4, 2011
