Iridescent Particles in Ardex's 8+9 Waterproofing - A closer look
Discussion in 'Shower & Bathtub Forum & Blog' started by johnfrwhipple, Oct 26, 2012.
  1. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Post(s) removed by John Whipple
  2. boardable
    boardable New Member
    Sep 27, 2012
    San Jose, Ca
    John, working in the automotive industry I know that is petroleum. Which means any petroleum that is in the ardex that did not get encapsulated is floating. no big deal. It could simply be something they use so ardex doesn't stick to the container it is in or in the manufacturing process.
  4. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Ardex's 8+9 Waterproofing - Iridescent Flood Test Layer
  5. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Ardex 8+9 MSDS Safety Data Sheet
  6. boardable
    Sep 27, 2012
    San Jose, Ca
    Vinyle acetate co polymer. Probably lighter than water so it floats. Take a dish and put in a tiny drop of motor oil in it. The sheen will be there. Take a tile spacer and drop it in a bucket. It floats. You have tested Ardex and you know it works well. Just be sure to clean the oil off before tiling.
  7. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Ardex's 8+9 Waterproofing - Technical Department
  8. boardable
    Sep 27, 2012
    San Jose, Ca
    John I am interested to find out what the rep has to say
  9. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Technical Feed Back from Ardex
  10. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Proper Mixing Paddle for Ardex 8+9
  11. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Ardex Testing in Vancouver
  12. boardable
    Sep 27, 2012
    San Jose, Ca
    I am really eager to hear what they have to say .
  13. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Ardex Duck Box - testing Ardex 8+9
  14. jadnashua
    FWIW, if I remember correctly, granite always contains at least these three minerals: mica, quartz, feldspar. Since sand can have many sources, it's not unreasonable that some of it could have been created from granite, but the majority of sand is quartz (highly purified suff might end up mostly quartz required for clear glass). But, mica does not disolve in water.
  15. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Mica Flakes in Ardex 8+9 - ??? Maybe
  16. boardable
    Sep 27, 2012
    San Jose, Ca
    Wow this is all very interesting I am staying tuned on this one.
  17. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Ardex 8+9 Product review for 2012
  18. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Gassing in Ardex 8+9 - Tiny pockets of air
  19. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Air pockets in Ardex 8+9
  20. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Irridescent layer on Ardex 8+9 - film layer on flood test
  21. Daler
    Daler New Member
    Aug 31, 2010
    Retired commtech
    Cowichan, BC
    Heya, John
    Don't know if this is the proper thread to talk about this or not...
    It's an interesting -- and timely-- review that you are doing. Too bad it's taken more than a year to complete it to your satisfaction :rolleyes:
    I am a layman homeowner who is just now putting in a 'custom' shower (36x58). My plan is to attempt a mud floor with a Kerdi drain, and cover it with Kerdi cloth (just enough material for the floor was given to me some time back) then up the sides about 8" with Kerdi-band. I'm not concerned with any warranty program so I'm thinking on using some Ardex X5 thinset under the Kerdi as well as for the field tiles -- that product was such a good choice for my other marble-tiled bath project. Have you used X5 under Kerdi?
    The shower walls are just now Hardi'd. I then plan on using the Ardex 8+9 for the walls with overlap down onto the Kerdi clothed pan.
    The Ardex package directions indicate that the Hardi seams and corners be filled and mesh-taped with the 8+9 -- no mention of pre-filling with thinset. But some of the gaps in the Hardi are large (about 1/4" at the niches for example). So what I propose to do is to first simply fill the Hardi with thinset and mesh-tape (as normal) then treat with the Ardex 8+9 as I did using the AquaDefense on my previous tub surround project. But my uncertainty here is with with the treatment of the corners as with the possibility of 2x4 stud movements. So, do you think the option of fully thinsetting the Hardi first would have any merit? As an aside, I've used Schluter eke for corner tile movement before and it seems to have worked as well as silicone.
    Also, can the Kerdi be glued together successfully using the 8+9, or should I stick with the X5 or even Kerdi-fix? ..I'm not sure of your results as your review has yet to be finished.
    And if so is there any advantage of just continuing the 8+9 over the whole Kerdi covered pan as a backup waterproofer? -- will it stick for the long term?
    After resolving this, I also want to include building of a proper (low profile) curb. I figured I'd build it out of formed concrete. Is there a cationary method to use in doing this? I would also cover this with the Kerdi cloth ..and perhaps with a coat of 8+9 as well.
Similar Threads: Iridescent Particles
Shower & Bathtub Forum & Blog Back to the black particles in the tub faucet and the toilet in the main bath.... Nov 23, 2016
Shower & Bathtub Forum & Blog Black particles in bath hot water only Nov 28, 2012
Shower & Bathtub Forum & Blog Black particles in bath water?? Jul 1, 2008
