IR Communication by using PT2248/PT2249A
Discussion in 'Bob & Don's Electronics Forum' started by munhann, Jul 6, 2011.
  1. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    No a cascaded emitter follower uses the same type of transistor, Typically 2 NPNs, I do believe.
    It is a complementary pair.
    I personally do not like to direct couple transistors, I would have put a 1K resistor on the base of Q2.
    But that is a mater of personal preference.
    With a limiting resistor at least if one transistor gos bad, It don't take out the other.
    Then you have to add more smoke, because it all gets let out. lol
    I hope You are having a enjoyable Weekend.
    DonL
  2. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    Just finished cutting the grass, so now its time to cool off.
    Factory smoke is hard to find these days!
  3. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I wonder what ever happened to this IR system ?
    Did you get it working munhann ?
    DonL
  4. BobL43
    Mar 25, 2011
    Long Island, NY
    So munhann?> you out there somewhere?
  5. PipeInspection
    PipeInspection New Member
    Apr 10, 2012
    New Jersey
    Realize this post is old. I'm new here and wondering if anyone has plans to Built a 512 Hz Transmitter. I found plans to build a Transmitter Tracker, but not sure how to turn it down to 512.
    512 is AM correct?
    Thanks in advance,
    Paul
  6. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    AM as in Amplitude Modulation? It is within the human vocal range. Middle C on the piano is 256 Hz.
  7. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Depending on the bandwidth it can be am/fm/cw/ssb or whatever you design it for. I would think CW is the norm, if you plan to use it as a Pipe locator.
    512 HZ is in the Audio range , so why not just use a audio generator / or a 512 HZ tape recording and a speaker ?
Similar Threads: Communication using
Bob & Don's Electronics Forum LED Lamp for Can light housings Jul 27, 2011
