Internal Pipe Cutter
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Esquire, Jun 8, 2010.
  1. Esquire
    Esquire Plumber
    Nov 26, 2009
    Newfoundland
    Just wondering what all you guys are using for internal pipe cutters? ie cutting the toilet pipe below floor level to install a flange. Usually find this situation when finishing a basement that was roughed-in during the building stage.
  2. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
  4. hj
    I slide the flange over the pipe, and then saw it off flush with the top of the flange. But then, I always use a 4" riser pipe. When it is a 3" riser that someone else installed, then I use the Ridgid #109 internal cutter.
  5. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    I use a Reed internal pipe cutter. I also carry both the carbon cut off disk and the steel saw blade to go with it.
Similar Threads: Internal Pipe
Plumbing Forum, Professional & DIY Advice Internal Pipe Corrosion near boiler fill valve. Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Can copper pipe coming out of be slab be sealed internally? Apr 5, 2014
Plumbing Forum, Professional & DIY Advice Help! Toilet losing water (internal), wakes me up at night because it refills tank Jul 5, 2015
Plumbing Forum, Professional & DIY Advice Toto Carlyle MS874114SG Replacement Part Numbers for all internal guts Jun 4, 2014
Plumbing Forum, Professional & DIY Advice leak in water softener internal valving Nov 29, 2011
