Internal Heat Traps
Discussion in 'Water Heater Forum, Tanks' started by teague6403, Aug 9, 2011.
  1. teague6403
    teague6403 New Member
    Aug 9, 2011
    Texas
    Can internal heat traps be replaced? I have a Rudd Pacemaker PE2-52 with internal heat traps. The cold water side is making loud metal clanking noise about twice a day that I believe to be a bad cold water internal heat trap. Normally the cold water pipe is warm, but when clanking starts, the cold water pipe is very hot. I can't seem to find a part number on any website for an internal heat trap. All parts references refer to external heat traps. Any help would be appreciated.
Similar Threads: Internal Heat
Water Heater Forum, Tanks Internal Heat Trap Jan 8, 2014
Water Heater Forum, Tanks New Water Heater - Scale, High pH / Alkalinity Saturday at 6:41 AM
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Feb 21, 2017
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
Water Heater Forum, Tanks HW Heater to tankless coil Feb 13, 2017
