SAS
Occasionally, we have warm water coming out of all the cold water faucets. I have checked the pipes by the recirculation system, but that does not seem to the culprit. The pump is connected at the top of the water heater and there is a check valve preventing hot water from flowing up into the cold water feed. Also, the recirculation pump runs continuously and the probelm is intermittent. The last time it occurred I noticed that it was right after the washing machine had run. Is it possible for the hot to flow into the cold from the washing machine mixing valve? If not, what else would explain an intermittent flow of hot water into the cold water line?
