Interior French Drain
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by barumord, May 8, 2007.
  1. barumord
    barumord New Member
    Apr 23, 2007
    I am in the process of choosing a company to install an interior french drain in my basement. So far I have 2 companies to choose from. The prices are about the same, however, one company uses PVC piping under the gravel while the other uses a flexible pipe. The one who uses a flexible pipe states it is superior to pvc because the holes in the PVC pipes are too large and it allows dirt to be sucked in. Additionally, pvc pipes only have one set of holes and can be installed at the wrong angle. The flexible pipes on the other hand have slits all over which is more beneficial. He also claims the flexible pipe will never crush. On the other hand, the other company swears that PVC pipes are the best way to go because they are strong and have a good history.
    Since I know very little about this stuff and do not want to get hooked by the better salesman, I am reaching out to the experts for a good opinion. Guys, help please ??
  2. NealinNevada
    NealinNevada New Member
    May 7, 2007
    I put in about 200' of french drain around the perimeter of my place and I used the flex tubing but I also put a sleeve over the pipe. It is a cloth sock that keeps most of the dirt out, but lets the water flow into the pipe.
  4. yar02169
    yar02169 Member
    May 7, 2007
    Quincy, MA
    I did about 120' of PVC pipe with drilled holes more than 20 years ago. We did it well before 'the sock' was invented, so we used small gravel to surround the pipe before backfilling the hole. I have not had iny issues since the install.
    My guess would be that if the 'sock' is used in either configuration, it will perform for a long time to come.
Similar Threads: Interior French
Pumps and Tanks Well Forum & Blog. Water is life. Interior Drain Tile Installation Dec 31, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Insulating Water Well Line into Interior Walls of Cottage - Chases for Copper Lines Feb 5, 2011
Pumps and Tanks Well Forum & Blog. Water is life. new member old problem...french drain setup and well Mar 13, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Sizing sump pit for external french drain May 13, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Need Help !!! - French Drain/Pump Basin Sizing Jul 19, 2009
