Interior Drain Tile Installation
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by johngandersonjr, Dec 31, 2011.
  1. johngandersonjr
    johngandersonjr New Member
    Aug 17, 2011
    Hilbert, Wi
    Hello,
    I have some existing interior draintile in my basement that is working very well.
    I also have a fruit cellar in my basement and the walls are holding water. Currently no interior drain tile there.
    The fruit cellar is cinder block like the rest of the house. it also has footings all around the room including under the door way to get into the room.
    Does anyone know how I would connect new interior drain tile from the fruit cellar to my other 3" perforated tile in the adjoining room?
    The door way into the fruit cellar has a footing underneath and I am not sure how to get through? Do I break out a 3" diameter hole to get the tile through, go underneath the footing?
    Any and all help is appreciated!
    John
  2. johngandersonjr
    Aug 17, 2011
    Hilbert, Wi
    Any one Have an idea?
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The tile should be set even with the bottom of the footing, so going underneath would not work (you can't make water flow uphill).
    A structural engineer would determine whether the footing can be penetrated safely depending on the load, the dimensions of the footing, and the soil type.
    It would probably be easier to put in another sump in the room that is not connected to the existing tile system.
  5. ballvalve
    Dec 28, 2009
    northfork, california
    A hole in the fruit cellar floor for a 130$ zoeller pump is cheaper than any lengthy cement tear out.. Dont need tile, the hole will fill nicely on its own.
Similar Threads: Interior Drain
Pumps and Tanks Well Forum & Blog. Water is life. Interior French Drain May 8, 2007
Pumps and Tanks Well Forum & Blog. Water is life. Insulating Water Well Line into Interior Walls of Cottage - Chases for Copper Lines Feb 5, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Drain back system for drilled well Mar 13, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Basement Crock - Fibers in Drain Jan 8, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Drain Welll Tank annually? Oct 12, 2016
