Insulation/Vapor Barrier
Discussion in 'Remodel Forum & Blog' started by OBDECKS, Oct 27, 2008.
    OBDECKS New Member
    Oct 14, 2008
    Should I install a vapor barrier behind an acrylic surround?
    2 walls interior and 1 is exterior.
    On the exterior wall is the faced insulation enough of a vapor barrier?
    I currently have insulation between the 1st and 2nd floor of my house (Cape Cod). Both are used and heated. Should I replace or remove this when I replace ceiling in the 1st floor bathroom. 2nd bathroom is directly above.
  2. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    Technically the kraft paper used for the insulation is enough, but I always use 4mil poly on exterior walls. You don't, however, want two layers of vapor barrier in any wall. An easy remedy for this is to cut slits in the kraft at 2' intervals, then cover with poly.
    Not a good idea for vapor barrier in interior walls.
    The insulation between floors helps greatly to reduce noise transmission between floors. Leave it there. The builder took pride in his work obviously, since most leave this out.
Similar Threads: Insulation/Vapor Barrier
Remodel Forum & Blog Walkout Basement Insulation/vapor Barrier Question - Pic Included Apr 27, 2016
Remodel Forum & Blog Subfloor question about vapor barrier Dec 2, 2015
Remodel Forum & Blog 15 minute thermal barrier at top of 2 inch xps foam boards. Oct 23, 2014
Remodel Forum & Blog Vapor Barrier or Not Dec 28, 2013
Remodel Forum & Blog Thermal Barrier at top of XPS wall. Oct 25, 2013
