Insulation ok?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Andrew21, Oct 7, 2011.
  1. Andrew21
    Andrew21 Member
    Jun 21, 2006
    New York
    Hey all,
    I have a question.
    Is the insulation here ok? ( I did fill in the little void on the left hand side by the window..made sure of it!) This wall is against the outside wall and I just wanted to make sure that the insulation is ok before I screw it in and seal it up with Redgard.
    I'm worried that if I have to replace the shower valve that the torch will make the insulation go up in flames. But then again, I'm afraid of the pipes bursting behind the walls.
    p.s. I asked this on another forum. Sorry, just want opinions =)
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    If your in a cold climate, I wouldn't have put the valve on the outside wall. You could have used a right hand tub. It is a nice looking installation though.
    John
  4. Gary in NJ
    Gary in NJ Member
    Apr 11, 2010
    NJ
    It should be fine. Cutting down air flow is most important on an installation like this.
  5. hj
    You did NOT have to insulate the shower and tub spout lines because they are not "full of water" once the faucet is turned off. If you ever have to change the valve the wall insulation will probably be the least of your problems. If the water lines NEEDED insulation, then the elbows would also need it.
  6. TJanak
    TJanak Member
    Sep 9, 2009
    South TX
    If your fiberglass batt insulation is between the pipes and the outside wall (as it looks) I would not insulate the pipes. You want warm air from the interior to get to the pipes to keep them warm. As it is now you are blocking heat from the house from getting to the pipes.
    Kinda like when the say to open kitchen cabinets under the sink to keep the water lines from freezing.
  7. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Never put pipes on an outside wall. Insulation does not create heat. Given time and cold enough temperatures the pipes and valves will freeze.
  8. Andrew21
    Andrew21 Member
    Jun 21, 2006
    New York
    Thanks for all the replies!
    Just to let you know the plumbing was there already. I was not going to move it because that would be too much work.
    Anyway, thanks again and tile on!
Similar Threads: Insulation
Plumbing Forum, Professional & DIY Advice Pipes above or below insulation with unusual insulated slab on grade Jan 31, 2017
Plumbing Forum, Professional & DIY Advice pipe insulation for cold water Jan 14, 2012
Plumbing Forum, Professional & DIY Advice Pipe Insulation Apr 28, 2011
Plumbing Forum, Professional & DIY Advice Shower Steam Generator Pipe in Contact with "Pink" Insulation Jan 30, 2011
Plumbing Forum, Professional & DIY Advice Pipe insulation, what you should know Aug 22, 2010
