Insulating Water Pipes
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chefwong, Mar 18, 2013.
  1. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    Between Fiberglass vs. Armaflex, which material is more *insulating* for water pipes.
    I've noticed in commercial jobs, the guys use the fiberbglass wraps more.
    Love to hear the pros/cons
  2. jadnashua
    The one with the higher R-factor! That's usually the foam, but it depends on the thickness of each.
  4. hj
    Commercial jobs use fiberglass because the specifications usually call for it, and its specific covering, as well as appearances. The thickness determines its "insulation value" NOT necessarily the material.
  5. chefwong
    chefwong Member
    Jun 14, 2006
    If thickness is the case, then it must be fiberglass all the way. Without me comparing them in front of me, I'm thinking at least 2X as thick..
  6. jadnashua
    Unfortunately, you'd be wrong! Depending on the foam, it may have as much as R5/inch. Fiberglass is rarely more than R2/inch, and because it has more open air spaces, can radiate more, reducing its effectiveness because of convection in it. A closed-cell foam doesn't have that issue. Fiberglass doesn't give off toxic fumes if it burns, some foams can. Decide what you need for R-factor, read the specs, see how thick you need to go with the preferred material, but if space is an issue, foam wins.
  7. Hairyhosebib
    Hairyhosebib New Member
    Jun 23, 2010
    Arizona
Similar Threads: Insulating Water
Plumbing Forum, Professional & DIY Advice insulating my hotwater pipes Jul 5, 2011
Plumbing Forum, Professional & DIY Advice Insulating water lines in attic? Nov 2, 2010
Plumbing Forum, Professional & DIY Advice Insulating PEX hot water lines Apr 30, 2008
Plumbing Forum, Professional & DIY Advice value in insulating hot water pipes Nov 9, 2006
Plumbing Forum, Professional & DIY Advice 2 parter: Insulating water pipes and ball valve sweating May 7, 2006
