Insulating Outlet/Light Boxes
Discussion in 'Electrical Forum discussion & Blog' started by molo, Nov 9, 2011.
  1. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Are there any techniques that can be recommended for reducing the draft in a outlet/light boxes (specifically a box with 3 light switches?)
    Thanks,
    Bill
  2. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    Retrofit is difficult but in new construction use tape to close off all the holes in the box and some spray foam or caulk to seal the wire penetration. Use some siliconized latex caulk to seal between the edge of the box and the drywall.
  4. jadnashua
    They sell inexpensive foam pieces designed to fit over the switch or receptacle. For multi-gang ones, you can overlap them. They'll help with the breeze.
  5. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Is Spray foam in the box OK?
  6. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    no .
  7. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    If you are really motivated, you might consider opening up the wall to see where all that air is coming from. You may have a big leak or the insulators could have "missed" a stud bay.
  8. hj
    Usually the problem is "OUTSIDE" the box and needs insulation around it.
Similar Threads: Insulating Outlet/Light
Electrical Forum discussion & Blog Insulating plumbing / grouding wire Aug 8, 2013
