insulating around recessed lighting
Discussion in 'Remodel Forum & Blog' started by possum, Feb 26, 2007.
  1. possum
    possum New Member
    Feb 20, 2006
    western pa
    I have recessed lights in the bulkhead of my kitchen I can fill the cold air dropping right out of them I checked in the attic above them and there was no insulation in the bulk head is it safe to insulate around them or could this cause fire?? thanks for the help
  2. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Check the labeling on the fixture to see if it's rated for "Insulation Contact" oc "IC".
    If not, assume you have to keep insulation 3" away.
  4. jadnashua
    If they aren't IC rated, you could replace them or build a box around them with an air gap, then insulate over them. You might want to check with the manufacturer as to the required minimum air gap. After doing all of that, it might be just as easy to replace with a sealed IC rated fixture - these not only can have insulation over them, they are sealed so they don't leak air. An IC rated one is not necessarily also sealed, so check carefully. One I was actually looking at last night was rated at no more than 2 CF/hour infiltration, which is decent.
  5. jimbo
    jimbo Plumber
    San Diego, CA
    What you really want is fixtures designaed ICAT .... insulation contact, air tight. The air tight fixtures are sealed agains air loss or infiltration.
Similar Threads: insulating around
Remodel Forum & Blog Insulating cantilever and rim joists Dec 29, 2014
Remodel Forum & Blog Walkout basement finishing - insulating walls above and below grade Sep 9, 2014
Remodel Forum & Blog Finishing Basement - Insulating Walls and Floors May 16, 2013
Remodel Forum & Blog Insulating R5 'Penitentairy tile' walls Nov 20, 2012
Remodel Forum & Blog Insulating Brick home in OK? Aug 3, 2012
