Insulate undersized supply pipes to quiet them?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Buttonsrtoys, Jun 3, 2013.
  1. Buttonsrtoys
    Buttonsrtoys New Member
    Nov 1, 2012
    Nova Scotia, Canada
    I'm remodeling and ripped out all my 1" plaster and am replacing with 1/2" gypsum board. Because of this, I'm realizing how loud my supply pipes are. In particular, when a toilet or tub fills. It's a 60 y.o. house and the pipe's are 1/2" throughout, so undersized. The the pressure and supply are both fine, it's just the noise that's the problem. I don't have it in me to rip them out and am wondering if wrapping them with insulation would help. If so, is there a particular size or type? Any other advise would be much appreciated.
  2. hj
    noise
    The noise will be transmitted through the entire system, so insulation will probably not have a significant effect on quieting them.
  4. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    You might get better results by way of installing a pressure reducing valve, since lower pressure equals lower flows and quieter plumbing.
  5. Buttonsrtoys
    Nov 1, 2012
    Nova Scotia, Canada
    Thanks HJ. Due to my ongoing reno, I have access to 90% of the system (it's mostly in my exposed basement ceiling and one open wet wall). Do you think I'd still see negligible results?
  6. Buttonsrtoys
    Nov 1, 2012
    Nova Scotia, Canada
    I'd like that idea. Thanks!
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Note that a PRV usually needs a thermal expansion tank installed also. Neither of these are extremely expensive nor are they difficult to install.
  8. hj
    Prv
    Lower pressure equals lower flows, which is the same as lower volume, so your shower output may be adversely affected. The real problem is that your entire system is undersized, and you are trying to fix it by "putting band aids on a broken leg".
Similar Threads: Insulate undersized
Plumbing Forum, Professional & DIY Advice Pipes above or below insulation with unusual insulated slab on grade Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Pr e -insulated PEX Tubing Dec 30, 2016
Plumbing Forum, Professional & DIY Advice Exposed pipes in attic - insulate attic? Oct 24, 2016
Plumbing Forum, Professional & DIY Advice Cantilever seal and insulate prior to finishing basement Oct 7, 2016
Plumbing Forum, Professional & DIY Advice Pre insulated PEX Sep 29, 2016
