Insulate Pipes OUTSIDE wall and Kerdi around shower valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rsmith99, Mar 9, 2008.
  1. rsmith99
    rsmith99 Member
    Feb 28, 2008
    Oklahoma
    I am getting ready to insulate the pipes in my shower. This is on an OUTSIDE wall.
    I am going to use the black foam insulation and fiberglass insulation. My suestion is; should I split the fiberglass batting and tuck it in front of and behind the pipe or just stuff it behind the pipe?
    Also should the drywall and Kerdi be brought in tight around the shower valve or should I use the plastic rough-in spacer and only bring the drywall and kerdi up to the plastic?
  2. jadnashua
    Normally, if you get the Kerdi close enough to the rough-in piece and tile it, the eschution with its seal will complete things enogh so you don't need to bring the Kerdi further in. If you really want to seal that area, get a tube of KerdiFix (or another urethane sealant), and seal it to the valve. I don't recommend that, nor do I feel it is necessary since the trim plate should seal it well enough, and gluing to the valve can be a big pain if you need to do service. Around things like body sprays, depending on their trims and the seals they may have, you may want to seal the Kerdi to the fixture with the sealant.
    I would have tried to rearrange things so the pipes could be on an inside wall, but that's too late. You want the pipes in the room side of the cavity to get as much room heat as possible to prevent freezing. See what the concensus is before you jump off the deep end.
  4. rsmith99
    rsmith99 Member
    Feb 28, 2008
    Oklahoma
    Outside wall
    This is not new construction. I am replacing the original shower that fell apart because they did not use Kerdi. I have no choice but to put the pipes in the same place they were. All I did was replace the old PB with PEX and put in a new diverter.
  5. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    Around here (-20F design temp) you need to add ridged foam and try and keep the pipes near the drywall.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Ummm forgive me for asking but why can't the plumbing go in the wall to the right side of the shower?
  7. rsmith99
    rsmith99 Member
    Feb 28, 2008
    Oklahoma
    Outside Wall
    Because it is a corner shower. Both walls are outside walls.
  8. Redwood
    Dec 15, 2007
    Service Plumber
    Ahh I got you now... I was thinking there would be a third wall.
  9. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    We recently remodeled our bath in an old 1920's house. Exterior wall, stucco, cold winters. We used the closed cell expanding foam (not the rapid open cell stuff, it can hold water like a sponge). I think the product is handi-foam and they sell a DIY kit. It is not cheap, but it insulates the dickens out of small spaces.
    The water we get out of there is considerably warmer than it used to be.
  10. rsmith99
    rsmith99 Member
    Feb 28, 2008
    Oklahoma
    Is DOW GREATSTUFF safe to use around PEX?
    IS DOW GREAT STUFF spray foam safe to use around PEX?
  11. rsmith99
    rsmith99 Member
    Feb 28, 2008
    Oklahoma
    Bends In Pex
    Do any of the bends in the PEX pipe look too sharp?
  12. Bill Arden
    Sep 30, 2006
    computer programmer
    MN, USA
    I would be concerned with the bend at the outside corner since it will be hard to get it to turn 90 degrees and not go near the outside of the wall.
    I would have run the pipes vertically near the corner so you get a bend going down and then a bend going the new direction.
Similar Threads: Insulate Pipes
Plumbing Forum, Professional & DIY Advice Pipes above or below insulation with unusual insulated slab on grade Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Exposed pipes in attic - insulate attic? Oct 24, 2016
Plumbing Forum, Professional & DIY Advice Easiest way to insulate frozen pipes on exterior wall? Feb 17, 2015
Plumbing Forum, Professional & DIY Advice should we insulate pipes in crawl space of seasonal camp Nov 15, 2013
Plumbing Forum, Professional & DIY Advice Insulate undersized supply pipes to quiet them? Jun 3, 2013
