Mike Reilly
Good morning to you all,
In March 2015, I installed a new, residential Water Worker HT 30. It's a Water Worker again because it was a free, warranty replacement from Menard's [4.5 yrs. old]. Next one WILL be a Well-Xtrol.
All seemed to be going OK, but the last month or so, I started noticing the faucets can be flowing fine, and suddenly the flow nearly stops, the pump kicks in and we're off to the races again. I had the time to check it out this morning, so I was draining the tank at the tank faucet, with the house valve closed. It was flowing into the drain fine at a pretty good rate. Then the flow stopped instantly, like someone slammed a ball valve shut; no slowing down or draining to a trickle, nothing. Went from draining fast to Zero in a split second.
At the present time, the tank pre-charge shows 32 lbs. and the tank gauge shows "O". The pump kicks in at 34 lbs. according to one gauge, and 31 lbs. according to the other gauge. Don't know which to trust. One gauge [34] is on the tank valve, the other gauge [31] is in the house feed line about 10+ ft. away. Three hand gauges all agree on the 32 psi pre-charge.
Any helpful thoughts for me folks? I really appreciate it.
T'care,
Mike
T'care,
Mike
