Instant Hot Water Dispenser Problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Kiko, Feb 6, 2011.
  1. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    I have an Insinkerator instant hot water dispenser model SST-FLTR 2/3 Gallon. Lately, the water it dispenses is spitting and sputtering, as if air is getting into the system somehow. It happens randomly and is not related to the aerator. Any ideas of how air is getting into the system? There doesn't seem to be any leaks under the sink.
  2. hj
    Usually that means the water is getting too hot and is turning to steam.
  4. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    I turned down the thermostat and ran out all the hot water in the tank. It still spits and sputters, even with cold water, so air must be getting in somewhere. Are there any seals in the tank that could be tightened up?
  5. hj
    Air does NOT get into that unit. It is NOT under any pressure so there are no "seals" to tighten. When you "open" the faucet handle you send water into the tank and that forces water out of the tank and out of the spout. The only way air could get INTO the tank is if some water leaked out , or boiled away, so there was a space for air to take its place.
  6. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    I just talked to a service tech at Insinkerator. He said there is an in internal aspiration valve in the tank that could have gone bad, and since it is not fixable, he will send me out a new tank.
  7. jadnashua
    If I was going to guess, that valve is there to let air out so that the tank can fill with water. This is necessary to ensure the heating element is covered with water and doesn't burn up. The valve would close when the tank was at it's design fill height. If it leaked, you'd get water out. Once the tank is full the first time, it may never open again, as the incoming water pushes the stored hot out. It sounds to me that the thermostat is bad, and the water is hotter than design. Then, when you open the valve, because the pressure is off, it flashes to steam on the way out.
  8. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    I mentioned that the water sputters even after all the hot water is gone and only cold water is coming out. I don't see how there could be any steam getting through. Even if a fraction of the water "flashes to steam," it would surely condense back to liquid with all that cold water around it. Anyway, a new tank should fix the problem, unless air is getting in via one of the lines.
  9. jammy
    jammy New Member
    Apr 22, 2006
    Maryland
    Kiko: What was the final conclusion? I have the same issue. Did the new tank work?
  10. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    The fact that the OP never reported back after he said he was going to get a new IHH, may suggests that his condition went away.
    These units are not known to last a life time, and IMHO not worth fixing. I would replace it.
Similar Threads: Instant Water
Plumbing Forum, Professional & DIY Advice Waterstone #5000 hot tank, Instant Hot Apr 23, 2016
Plumbing Forum, Professional & DIY Advice Instant Hot Water from Kitchen Faucet Nov 27, 2014
Plumbing Forum, Professional & DIY Advice Instant hot water dispenser Oct 10, 2011
Plumbing Forum, Professional & DIY Advice Reverse Osmosis to Instant Hot Water? Jul 22, 2011
Plumbing Forum, Professional & DIY Advice Watts Instant Hot Water Recirculating System Dec 14, 2009
