Installing Water Softener
Discussion in 'Water Softener Forum, Questions and Answers' started by jacksmith7, Feb 13, 2009.
  1. jacksmith7
    jacksmith7 Member
    Sep 13, 2004
    I'm installing a water softener that has to be about 45' (as the pipe runs) from where the main line enters the basement. Currently, there is a branch-off from the main line about halfway...this supplies the master bath.
    I plan to cut the main line just before it branches off to the master bath and run new piping from there to the water softener. Rather than run new piping all the way back to where I cut into the main line to tap back into the original piping (just before the master bath), I plan to cap it there and tee off of that original piping closer to the water softener.
    What the end result will be is the line leaving the water softener will tee into a line that goes one direction to supply the master bath and the opposite direction to supply the water heater and the rest of the house. All piping will be 3/4" copper. Is there anything wrong with the way I plan to do this? Thank you.
  2. Gary Slusser
    Retired
    Yes, you'll create a deadend with the cap just before that tee to the bathroom. So replace the tee to the bathroom with an elbow.
  4. jacksmith7
    jacksmith7 Member
    Sep 13, 2004
    Thank you, Gary. I was afraid I may not have described the situation well enough for it to be understood, but you understood it exactly. I'll take your advice and replace the tee...thank you again.
    Jack
Similar Threads: Installing Water
Water Softener Forum, Questions and Answers Advice selecting and installing water softener Jan 12, 2017
Water Softener Forum, Questions and Answers Is it normal for water to smell odd after installing filter and softner Mar 5, 2016
Water Softener Forum, Questions and Answers Help installing water softener Nov 2, 2014
Water Softener Forum, Questions and Answers Installing used Culligan water softener + Potassium tank Apr 21, 2014
Water Softener Forum, Questions and Answers Installing a replacement water softener Oct 6, 2013
