Installing washing machine drain in basement apartment, venting/stack Question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ShaneB, Feb 24, 2012.
  1. ShaneB
    ShaneB New Member
    Feb 24, 2012
    Ontario Canada
    I have a question about modifying a current copper soil stack/vent to add a washing machine drain in a basement apartment that I will be renting shortly.
    The current plumbing setup behind the basement washroom looks like this:
    [​IMG]
    Can I cut a section of the copper stack out, replace with PVC, raise the current vent to above flood level of the bathroom fixtures behind the wall, and use a sanitary tee to a trap etc. just about where the current 45 comes off of the main stack for the breather?
    New proposed plumbing:
    [​IMG]
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    It is not clear to me what you are trying to accomplish. A horizontal vent needs to be above the flood rim of the highest fixture served, but your drawings show a vertical vent.
    We would need to know what size and type of fittings are being used to determine if if what you intend to do is right or not.
    In most of the U.S., you would be required to be a licensed plumber to perform this type of work in a structure that you do not own. I don't what happens north of the border.
  4. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    If you have a vertical vent stack, why are you tying into the copper stack with your vent?
Similar Threads: Installing washing
Plumbing Forum, Professional & DIY Advice Installing new washing machine Mar 25, 2007
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Pressure loss after installing PEX in place of copper Dec 8, 2016
Plumbing Forum, Professional & DIY Advice Installing a Samsung Dishwasher with existing Johnson Tee Nov 22, 2016
Plumbing Forum, Professional & DIY Advice Installing a sink for toddler Nov 22, 2016
