Installing Utility Sink sharing drain pipe on adjacent wall
John Brosnan
North Carolina
Hey folks I have a 20 year old home (was built to code here in NC) that has white plastic pipes. I guess the water lines are CPVC and the drain pipes might be the same or PVC. I want to put a utility sink in the laundry room adjacent to the hall bathroom. The wall behind the bathroom sink will be where the new utility sink will fit. I have not cut into the wall yet in the laundry room but do have a picture from under the sink. If I tie into the drainage pipe above or below the other T from bathroom sink will I need a separate vent pipe? I looked for a double Y at Lowes but they didn't have them. I am pretty sure the drain pipe also vents all the way to the attic above the second floor. (I think the A/C condensation line goes into the same pipe, up in the attic). I am no plumber but I have done some soldering w copper and I installed my new gas water heater and have used the shark bite fixtures too. I want to make the job as easy as possible. What would you recommend for tying into the water lines too? Thanks,
John
John Brosnan
North Carolina
Disregard my first post. Got those questions answered. Here are pics of the area I have to tap into. Do t worry I am moving forward but have one question about the distance from the sink drain to the P trap. Based on what I have to work with it is going to be about 14.5" from drain to bottom of P trap. Is this going to be a problem? Thanks in advance for your help.
