Installing Toto Carlyle II - water supply
Discussion in 'Toilet Forum discussions' started by Poschspice, Aug 13, 2013.
  1. Poschspice
    Poschspice New Member
    Aug 13, 2013
    Portland
    I have 7" from center of toilet rough in to center of water supply but it's only about 3" off the floor. Current shut off valve is standard cheaply type so it is wider that the supply. Will this be sufficient for clearance of the skirted bowl or should I have the supply line moved over and up?
    I have read both 6" and 7" from center will work but manual recommends 8" out and 6" up.
  2. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Terry has previously posted that the Carlyle II needs 6" center-to-center for the shutoff valve if it's on the wall. Doesn't matter how high off the floor it is for these purposes. If the handle is too big to turn, replace the stop with quarter-turn ball valve with a small-diameter handle, like on these angle stops. http://www.dahlvalve.com/PDF/Skirted_Toilet_Brchre_US.pdf Replacing the stop is normally a trivial job. Also note that those Dahl stops are ideal in the case (unlike yours) where you don't have enough distance from the centerline -- no need to relocate the water supply, just use a stop with a 90-degree turn built-in.
  4. Poschspice
    Aug 13, 2013
    Portland
    Thank you for clarification on this.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Aside for a better fit, these valves are far better than the old kind. Toilet supply valves should always be fully open, so no need to have one that requires 6 or 8 turns. Quick and easy to go from on to off, off to on.
  6. Reneecase
    Reneecase New Member
    Mar 27, 2016
    Washington
    a
Similar Threads: Installing Toto
Toilet Forum discussions Installing a toto ultramax II Jan 31, 2017
Toilet Forum discussions TOTO THU9090R adapter for installing a Washlet on an Aquia Oct 13, 2016
Toilet Forum discussions Installing a wall-hung Toto Aquia toilet Jun 18, 2013
Toilet Forum discussions [HELP] Installing TOTO Washlet on existing TOTO Aquia II toilet Mar 8, 2012
Toilet Forum discussions Installing Toto Ultramax question Nov 11, 2011
