Installing Stiebel Tempra 24 Electric...Wire!
Discussion in 'Tankless Water Heater Forum' started by Rockin Rog, Mar 14, 2014.
  1. Rockin Rog
    Rockin Rog New Member
    Oct 1, 2013
    Ontario Canada
    Hey, just throwing this out there because I'm about to attempt this at home up here in Northern Ontario on my rural farm. I have no Gas or Propane...just electric so here goes.
    My service is 200 Amps, my transformer is located on my pole outside and I believe I'm the only one on it and our lines were all upgraded about 2 years out here in our township concession.
    I have a 40 gallon tank that is about 30 years old now (Rheem Rudd) and is running like a champ still unbelievable. Regardless, I want to play with something new and I'm renovating downstairs and I like to tinker and get into trouble and I'm bored so I bought the Tempra 24 out of curiosity.
    Now I have done/do most all my own electrical here on the farm and yes we do have an inspector check around often enough, in fact he was just here a couple months ago. Regardless I am locating my unit around 20 feet from the main panel that is in line of sight. Would I have to have a sub panel for my unit? Should I notify the Electrical Power Co about my intention to install this unit?
    For electrical lines I am told I need 2 60 amp Square D breakers and run 6-2 lines. About the 6-2 lines I have found this wire...
    Does this wire have the proper amp capacity that I am needing and if so I then run from each breaker to the unit with this. At the heater from what I reading I don't hook up the ground? Is that correct or?
    Thanks Roger.
Similar Threads: Installing Stiebel
Tankless Water Heater Forum Saving water here in California buy installing mini water heaters at point of use. Jun 3, 2016
Tankless Water Heater Forum Installing 2 Tankless - Did my plumber do it right? Sep 5, 2014
Tankless Water Heater Forum Installing gas heaters & tankless water heater, Jacuzzi J-sp-180w Apr 5, 2013
Tankless Water Heater Forum Installing a Tankless Water Heater, with Video Feb 24, 2011
Tankless Water Heater Forum Stiebel Eltron Tempra 29 Plus, issue with shower Dec 7, 2013
