Installing Shut Off Valve on copper pipes
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by flicker55, Aug 3, 2007.
  1. flicker55
    flicker55 New Member
    Aug 3, 2007
    Teacher
    Southern Illinois
    I'm installing shut off valves on 1/2" copper pipes running from the floor to my kitchen faucet. These are compression valves. Do I have to bleed water from the pipes like you do when you are using solder or can I just make sure the water supply is shut off to my upstairs?
  2. jadnashua
    Just make sure you shut off the water. You need two wrenches, one to hold the valve from spinning, and the second one to turn the compression nut. Some people find a small drop of oil on the threads means you get a little smoother action when tightening the nut, but is not required.
  4. flicker55
    Aug 3, 2007
    Teacher
    Southern Illinois
    Thanks for the quick reply
    Thank you for the advice. I'm grateful.
  5. got_nailed
    got_nailed DIY Senior Member
    Jan 11, 2006
    I like to cut off about 1/2†of the old copper and sand them down a bit before I put new compression fittings on. I don’t know if it is needed but it’s one of my habits.
Similar Threads: Installing Shut
Plumbing Forum, Professional & DIY Advice Need help installing vanity over shutoff valves Sep 26, 2013
Plumbing Forum, Professional & DIY Advice Help installing shut off valve on copper pipe Sep 21, 2009
Plumbing Forum, Professional & DIY Advice Installing individual shut-off valves in condo building Feb 24, 2008
Plumbing Forum, Professional & DIY Advice Installing Shutoff Valves in Galvanized System May 23, 2007
Plumbing Forum, Professional & DIY Advice Installing shut-off valve in main line Feb 27, 2006
