Fixr
Hi,
I will be repiping all of my water lines with PEX in the near future. During the repipe, I also want to rough in water lines for a future bathroom addition in the basement (bath, sink, toilet). The roughed-in water lines will be home runs from a central PEX manifold. However, the sewer drain lines for the bathroom addition are not yet installed. The space where the bathroom will go is in an open space in the basement, with no framing or electrical yet installed. The existing drain pipes also needs some work to bring them up to code but I am hoping to do that separately and hire out the work after I finish the repipe.
So I have a few questions to make sure I'm approaching this the right way from both a code and project planning perspective:
Jay
- Can I rough-in the water lines for the new bathroom, without having the sewer drain lines installed?
- What state do the rough-in lines need to be in to pass inspection? Since valves/fixtures can't be installed until after drywall is in, will I need to use PEX terminators without valves/fixtures?
- How long can I leave the water lines in rough-in state?
- The previous owner did some sub-par work on the drain lines, without a permit. Main issue is the washer/utility sink drain is not connected to the system (it's air gapped, lazy plumbing) and flows into an open floor drain in the basement. This is the same area where the new bathroom addition will go. When I repipe, will the inspector require the open drain to be corrected? Will I be forced into doing the drain work now? Or can the supply piping and drains be worked separately?
Jay
