Installing new tub and surround in bathroom
Discussion in 'Shower & Bathtub Forum & Blog' started by John Fouse, Jun 2, 2013.
  1. John Fouse
    John Fouse New Member
    Jun 2, 2013
    Florida
    We bought a Sterling Ensemble tub & surround and two of the walls have studs to connect it to - the back wall is cinder block. My question is do I need to have 2x4s on the back cement wall or can I tapcon the surround and tub into the block wall itself and use shims?
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The tub should be set in a mortar bed, and the only screws I remember going into the surround are along the top edge. Kohler is quite specific about where the studs should be when building.
    If there is some reason not to use full dimension framing, I would at least use furring strips to keep it off the concrete.
    You must use pan head screws around the flange edge or it will crack when the screw is tightened. Lath screws are preferred, as the heads are thin and do not interfere with the overlaying wallboard.
Similar Threads: Installing surround
Shower & Bathtub Forum & Blog installing a tub and a one piece surround... Oct 27, 2006
Shower & Bathtub Forum & Blog Demo'd Fiberglass Shower & Installing New Tile Shower But I Have Questions??? Saturday at 2:13 PM
Shower & Bathtub Forum & Blog Installing a Panasonic bathroom exhaust fan in a condo Feb 9, 2017
Shower & Bathtub Forum & Blog Installing a washer drain 1 ft from main stack - is vent necessary? Jul 17, 2016
Shower & Bathtub Forum & Blog Installing code-compliant 2 handle shower faucet Jun 20, 2016
