jbiddle
I'm about to have a contractor replace my standard 50 gal hot water heater with a high efficiency tank type (HTP Phoenix LD 50 gal) and I'd rather decide what I want installed instead of leaving it up to him (of course his input will be considered). Last year I replaced replaced my HVAC with a high efficiency model and my water heater is now orphaned on the stack. My current water system does not have either a mixing valve or an expansion tank and I'm thinking of having both installed with the replacement. Here is my water meter; I think the device on the output is a residential dual check?
Would the Caleffi mixing valve with gauge and checks (#52519AC) model be a good choice. My intent is to set the water heater at 140 and the mixing valve at 120. If it matters, I want to leave open the possibility of adding a recirculating system in the future.
Also, my dishwasher has it's own heating element and my high efficiency washer has a heater for sanitizing (mostly I wash with cold or warm water) so I don't think I'll need to pipe any hot water directly from the heater, do you?
Is the Therm-X-Trol ST-5 a good choice ? My water pressure is at 65psi now but I've seen it fluctuate from 45psi to 80psi over the years.
Is there any benefit to installing the water heater on a riser (basement location)?
Thanks in advance for your help.
