Installing Moen A725 Drop Ell
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by seaneys, Feb 17, 2008.
  1. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    Hello,
    I've checked Moen's web site for this, but do not see the answer..
    I am installing a Moen A725 Drop Ell (seems like their standard). It accepts a 1/2" NPT Male.
    Does anyone know if the Male connection should be flush with the finished wall? I do not see any documentation that indicates the depth of the connection. I scoured their web site.
    Thanks,
    Steve
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    If I recall the threads should sit 3/8" outside the tile surface. Each manufacturer has a slightly different measurement.
    To be sure: What I usually do, I install a 1/2 copper x 1/2" fip wingback 90 fastened to a backing inside the wall. (similar to the shower arm 90). Once the tile surface is established, I install the A725 with a brass nipple to accomadate the distance needed for a flush mount.
  4. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    Do you use the same trick for the body jets? My only fear would be a leak in the wall, but I could always pressure test after the drop Ell was installed.d
    Steve
  5. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    Always the same thing. I always found that each contractor would finish their walls with different material thicknesses. The difference would be from standard 1/4" tile to 3/4" granite. Allow at least 3/8" for threads for each side . Total 3/4"-7/8"
    Doing it the way I mentioned, you can adjust the lenghts of the nipples as you see fit. Contractors or clients may have a change of heart in materials used and the plumber would never get notified of the changes until the project was ready for finishing. (then its too late.)
Similar Threads: Installing Moen
Plumbing Forum, Professional & DIY Advice Problems installing Moen shower valve. Jul 11, 2010
Plumbing Forum, Professional & DIY Advice Installing a moen faucet: PVC gasket vs silicon Nov 9, 2008
Plumbing Forum, Professional & DIY Advice Installing Moen Roman style Kitchen Faucet w/ sprayer Jun 28, 2006
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Wednesday at 10:36 PM
Plumbing Forum, Professional & DIY Advice Pressure loss after installing PEX in place of copper Dec 8, 2016
