installing linoleum flooring directly on conrete
Discussion in 'Remodel Forum & Blog' started by miner49er, Oct 23, 2007.
  1. miner49er
    miner49er New Member
    Oct 18, 2007
    hello,
    i am installing a bathroom (toilet/sink) in my basement.
    1) i've read about Saniflo's ---Saniplus toilet system? Whats your opinion on this toilet system?
    2) i would like to install linoleum flooring directly on the concrete in the basement. Is this an easy task? how do you do it?
    all advice would be appreciated.
    thanks
  2. jimbo
    jimbo Plumber
    2) Before installing any flooring in the basement, you would need to do a moisture test on the concrete. If there is any moisture present, this will present a problem, and require a moisture barrier.
    Then, of course sheet flooring requires an absolutely smooth and flawless foundation, so the floor would probably have to be skimmed, patched , etc. This part is very doable .
  4. Bosun
    Bosun New Member
    Jan 25, 2005
    Teacher
    Minneapolis
    skip the Lino
    I'd go with cermamic tile. A bit more money now, but the labor on your lino install is going to add up.
  5. miner49er
    Oct 18, 2007
    how do you test for moisture?
    if not acceptable, what is the moisture barrier that you would use?
    why tile?
    which product would be "warmer" on the cold floor?
    i appreciate all the answers that i get!!
  6. jadnashua
    Take about a 2' square piece of plastic and tape it down to the floor for 24-hours. See if there is any accumulated moisture under the plastic at the end of that time.
    The linoleum will be the same temp as the tile, but the tile will feel colder. They both will feel cold, though. Consider electric heat mats.
  7. jimbo
    jimbo Plumber
    1. what JAD said.
    2. you can paint the floor with a moisture barrier like RedGuard. This is not smooth enough to put sheet goods on, but would be a good base for ceramic tile, including the under-tile heat mats if desired.
  8. jadnashua
  9. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    cork tiles are the warmest. They are a sandwich of MDF between layers of cork.
    that is the cheapest solution. The next best thing to a heated tile floor.
    i.m.o.
    david
  10. Bosun
    Bosun New Member
    Jan 25, 2005
    Teacher
    Minneapolis
    I love tile
    If you have the tile done correctly, you will be happy for many years. I'm not a huge fan of sheetgoods, but some people are. If you have a lot of space to cover, sheetgoods are a great way to save money.
    Both will be the same temp. Both will be cold in the winter. Look at the little LV heat mats they sell at the big boxes.
    Make sure the man. and installer will warranty below grade installations. I know that some wont.
  11. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    David - cork tiles in a bathroom?
Similar Threads: installing linoleum
Remodel Forum & Blog Installing DOMJSO double-sink without countertop on a single 36" cabinet Feb 29, 2016
Remodel Forum & Blog Installing Kohler K-1160G Air Bubble tub Feb 14, 2016
Remodel Forum & Blog Installing Dishwasher Aug 18, 2014
Remodel Forum & Blog Installing a single oven below the counter. Anyone done this? What size base cabinet? Jun 4, 2014
Remodel Forum & Blog I am thinking of installing these allen + roth slate tiles... But.. Apr 25, 2014
