Installing Grundfos recirc pump on Power Vent 2 Rheem 83 gal WH
Discussion in 'Water Heater Forum, Tanks' started by orphiekid, Dec 1, 2012.
  1. orphiekid
    orphiekid New Member
    Dec 1, 2012
    Prescott AZ
    I want to install a Grundfos recirc pump on a 83 gal water heater that has a power vent on it. The pump would be installed on the hot water side and be plugged into a 110v outlet. My main question is would I have to shut down the power vent system (unplug it) and would something have to be reset when I am finished installing the pump. I would also install the manifold under the sink the longest distance from the heater. The pump has a 10' cord but the nearest double outlet is more than 10' away. Can I replace the single 110v outlet that provides power to the power vent with a double outlet so that I have power available for the recirc pump. Any help would be appreciated.
  2. Terry
    Aug 17, 2004
    Power goes on and off anyway. If you need to unplug the water heater and replug, you're fine.
    Powering both with the same outlet would be fine.
  4. orphiekid
    Dec 1, 2012
    Prescott AZ
    Should I shut off the gas supply while installing the pump since I will have to drain the hot water pipes per Grundfos instructions. Thanks
  5. Terry
    Aug 17, 2004
    If you are installing the pump above the water heater, you can leave the water in the tank. You can turn the pilot down to the vacation setting while you are working.
  6. orphiekid
    Dec 1, 2012
    Prescott AZ
    Thanks a million. Really appreciate the help.
  7. hj
    From your description, you appear to be installing a Grudfos "Comfort system", and if so the pump HAS to connect to the piping on top of the tank so almost nothing has to be drained. The only reason to turn off the switch on the control is so the heater does not start while you are working next to the "chimney". You change to a "duplex" receptacle or use a "grounded triple tap" into your single one with the heater and pump plugged into it.
Similar Threads: Installing Grundfos
Water Heater Forum, Tanks Installing new Phoenix water heater, expansion tank too? Mar 12, 2016
Water Heater Forum, Tanks Installing a new water heater Jul 28, 2015
Water Heater Forum, Tanks will installing two water heaters work Oct 3, 2013
Water Heater Forum, Tanks Installing an electric water heater in series with boiler Apr 17, 2013
Water Heater Forum, Tanks Installing 2 electric heaters Feb 14, 2013
