Installing flooring & toilet flange
Discussion in 'Toilet Forum discussions' started by lucgallant, Sep 11, 2011.
  1. lucgallant
    lucgallant New Member
    Jan 22, 2011
    Electrical Engineer
    Fort McMurray, Alberta
    Hi everyone,
    looking to get an opinion on something that most of you guys will probably deem a no brainer. I've had to pour self leveling concrete in my bathroom to get things level and this has caused the top of the toilet flange to be level with the concrete. I'm going to be putting in flange extenders to get the proper height. I'm just putting in some flooring now (glueless vinyl). My question is, do I cut the vinyl around the flange and make sure that it is not between the existing flange and the extensions, or do I need to compress the flooring between both flanges?
    I would do the first option but I want to bounce it off the pros. Thanks!
    Luc
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Cut the flooring around the flange. Also be sure the flange is screwed down to the floor.
    John
  4. lucgallant
    Jan 22, 2011
    Electrical Engineer
    Hi there,
    do you mean the flange extensions screwed into the existing flange/concrete?
  5. pdhawthorne
    pdhawthorne In the Trades
    Sep 11, 2011
    rockville, va
  6. jadnashua
    Ideally, the flange would be removed and reinstalled on TOP of the finished floor. But, when adding extension ring(s), you need a good seal to the flange, and the flooring would be a leak path, so do not sandwich it between the ring and the flange.
  7. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    If the existing flange is well secured to the floor, securing the extension to the existing flange would be adequate. You might want to get new bolts that have not been cut to length so that they can engage the existing flange and not just the extension.
  8. lucgallant
    Jan 22, 2011
    Electrical Engineer
    Ok, thanks everyone, this helps a lot.
    The instructions for the extensions say to use silicone to seal all the extensions to the base flange, is that method generally accepted or should I use another method?
    Luc
  9. jadnashua
    Follow the manufacturer's instructions...clean things off as well as you can first - silicon won't stick to wax, for example, and rust isn't a great idea, wire brush helps there.
Similar Threads: Installing flooring
Toilet Forum discussions Questions about re-installing a toilet after reflooring Apr 2, 2008
Toilet Forum discussions Installing toilets over wood flooring Sep 5, 2006
Toilet Forum discussions Installing a toto ultramax II Jan 31, 2017
Toilet Forum discussions TOTO THU9090R adapter for installing a Washlet on an Aquia Oct 13, 2016
Toilet Forum discussions Porcher Veneto: Need help installing Piston Jul 9, 2016
