Installing Cutler Hammer Surge Protector
Discussion in 'Electrical Forum discussion & Blog' started by basketboy, May 15, 2010.
  1. basketboy
    basketboy New Member
    May 15, 2010
    Pennsylvania
    I bought a Cutler Hammer CHSPULTRA whole house surge protection device, which comes with 4 wires: two go to a 2-pole breaker, one that goes to the neutral bus bar and the fourth wire that is meant to go to the ground bus bar. My load center does not have a separate ground bus bar. Any idea if both wires can be wired to the neutral bus bar or do I need to have a separate ground bar installed? Cutler Hammer's website was no help. Thanks in advance for any suggestions.
  2. Ian Gills
    Jul 24, 2007
    USA
    If this is the main service panel, then yes they can, but make sure they go under seperate lugs.
  4. basketboy
    May 15, 2010
    Pennsylvania
    Thanks for the reply. It was the main service panel so I did as you suggested. Surge protector is up and running.
  5. hj
    SInce the neutral and ground eventually wind up in the same place, using both would be a "belt and suspenders" approach to it.
  6. Ian Gills
    Jul 24, 2007
    USA
    Given through those are where any surge will end up, I still think two are better than one.
Similar Threads: Installing Cutler
Electrical Forum discussion & Blog Installing an AFCI breaker Jan 5, 2017
Electrical Forum discussion & Blog Homeowner installing electric to hot tub Nov 30, 2014
Electrical Forum discussion & Blog Installing Garbage Disposer electrical Jun 18, 2014
Electrical Forum discussion & Blog What to do with wires when installing light switches/plugs Sep 9, 2013
Electrical Forum discussion & Blog Grease on new Siemens circ. breaker contacts - need to wipe out before installing? Aug 13, 2013
