Installing coupling/pipe/bend in a tight space
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nc8861, Aug 21, 2008.
  1. nc8861
    nc8861 New Member
    Jun 25, 2008
    North Carolina
    I'm replacing a closet bend and a small section of 3" pipe going out to the main stack. My bend currently comes right up against a joist. So I don't really have much clearance on that end - and of course I don't have any clearance on the stack end. I have to cut the current stuff out, install a coupling, section of new pipe, then the bend (the bend has to come up in the same spot). So how do I get the same length/measurements in a space with no clearance? It's not like I can bend the coupling or pipe.
    On another board it was suggested that I use a shielded coupling that tightens down with screws. I'd really like to avoid anything but ABS + cement, as I don't want my toilet "stuff" going through a non-cemented joint. Is there any magical way to do this?
    [​IMG]
  2. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Tight Space
    Yes Call A Plumber ! ! !
  4. Terry
    Aug 17, 2004
    At this point, I like the shielded coupling.
    [​IMG]
  5. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    How about a repair coupling?
  6. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    Get a pipeshredder or rambit and cleanout the hub of the tee on the stack and then repipe.
  7. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Is there enough 3" pipe coming out of the tee on the main stack for you to glue on a 45? You might be able to replace that closet bend with two 45s to make a connection to the flange.
Similar Threads: Installing coupling/pipe/bend
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Wednesday at 10:36 PM
Plumbing Forum, Professional & DIY Advice Pressure loss after installing PEX in place of copper Dec 8, 2016
Plumbing Forum, Professional & DIY Advice Installing a Samsung Dishwasher with existing Johnson Tee Nov 22, 2016
Plumbing Forum, Professional & DIY Advice Installing a sink for toddler Nov 22, 2016
Plumbing Forum, Professional & DIY Advice Installing SDR-21 - 600ft Oct 11, 2016
