installing a tub and a one piece surround...
Discussion in 'Shower & Bathtub Forum & Blog' started by zbaise, Oct 27, 2006.
  1. zbaise
    zbaise New Member
    Oct 27, 2006
    In what order should I do the following...
    Should I glue or caulk the tub and surround then attach to walls or attach to walls and then caulk? My wife says someone told her that we should use adhesive to secure the surround to the tub and then caulk the seam, is that correct or is tub 'n tile caulk sufficient?
  2. jimbo
    jimbo Plumber
    We need more details about what brand and model we are dealing with.
  4. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
  5. Cass
    Cass Plumber
    Nov 12, 2005
    I reciently used some Power Grab for tub surrounds and I am hooked on the stuff.
  6. hj
    surround
    What do you mean by a one piece surround. If it is truly a one piece unit then it has to attach to the tub before the walls are installed because it would be designed for a specific opening size, and that is the same size as the tub's before any wallboard is installed. Once the drywall is in place the opening becomes smaller and a one piece unit should be too large for it. A one piece unit could not be designed to fit inside the walls because every space/room would be different.
Similar Threads: installing piece
Shower & Bathtub Forum & Blog How do I hook up the drain when installing a one- piece fiberglass bathtub drain Jan 6, 2008
Shower & Bathtub Forum & Blog Installing one piece Fiberglass tub and shower Aug 20, 2007
Shower & Bathtub Forum & Blog Installing a Panasonic bathroom exhaust fan in a condo Feb 9, 2017
Shower & Bathtub Forum & Blog Installing a washer drain 1 ft from main stack - is vent necessary? Jul 17, 2016
Shower & Bathtub Forum & Blog Installing code-compliant 2 handle shower faucet Jun 20, 2016
