Installing a Toto Drake CST744 or CST454CEFG 2-piece toilet written by Jamie Love
Status
Not open for further replies.
Jamie Love
Plumbing expert
Seattle, WA
www.outfromunderneath.com
Hey there everyone! I am Terry's son Jamie.
Installing a Toto CST744S toilet or TOTO CST454CEFG instructions by Jamie Love
I install hundreds of these a year so I have some quick and easy advice for
you. First off these toilets are assembled like every other two-piece on
the market. Lets not over think this one here, just becasue it is a
Japanese brand doesn't mean there is a "Foreign" way to put them together.
Remember they were first manufactured in Atlanta, Georgia and the instructions are in English.
So let's Go!
I'll walk you through an assembly. It should take less than 5 minutes.
1- remove tank and bowl from their respective packaging. (1 minute)
2- lightly sand the bolt holes inside the tank to ensure a smooth surface
for the rubber washer to contact. (30seconds)
3A- Using large pliers, give the large nut at the bottom of the tank a bit of a snug, then push the rubber gasket onto the bottom of the tank until it is flush.
The flat side should be facing the tank while the tapered end should be
pointing towards the bowl. I find a half twist will really snug it flush.
(30 seconds)
3B- slide rubber washer onto bolts and drop into holes inside the tank. Then place a washer and nut on and snug them up.
(30 seconds)
4- Set the toilet bowl on the flange without wax, to see how the floor is.​
Determine if any shims are needed.
I prefer to shim at the back, pinning the front of the bowl down.
We use the composite shims located in the windows and door section of HD.
5- Lift the bowl back up.
6- Next, set either one wax ring or two down on the flange.
If the flange is setting above the floor, one will do.
If the flange is setting on the lower plywood, not on the underlayment, then two wax rings.
7- Set the bowl down on the wax, drop the cap securements over the bolts, then washers and nuts.
Snug these down, making sure the toilet bowl is steady and not rocking.
There should be no bowl movement when you are done.
8- set the tank on top of the bowl until it is centered left to right and
front to back. (30 seconds)
9- Place washers and nuts onto the tank bolts after it has been placed on the bowl.
(30 seconds)
10- tighten down each side with the washers and nuts provided. I alternate
until snug. it is not neccessary for the tank to touch the bowl on all
sides, a little gap all the way around is fine. (2-3 minutes)
11- At the very last, you can caulk around the base. In Washington State, around the front of the bowl, leaving the back open. I use polyseamseal.
In Phoenix, hj would prefer that you caulk all the way around.
12- Crack a cold one and continue to pat self on back while you stand before
your throne in all it's glory! For you sir have just built one of the
finest toilets in the world!!! (15-30 minutes)​
13- Invite neighbor over so you can brag (1-2 hrs)
PS- I assume the seat install is self explanatory?
I hope this helps! Good Luck, Jamie
Consumer Toilet Report
The Toto Drake uses a Korky Quietfill valve and a Korky 3" flapper, made in the US.
The porcelain may be made in, USA, Japan, China, Viet Nam, Mexico.
The only caulk we use is between the floor and the base of the bowl, which we apply after the toilet is installed.
Even though it's considered to have a 12" rough-in, it will install with as little as 11" from the finished wall to the center of the flange.
The water supply at the wall should be 8" to the left of center, but will work with as little as 3".
https://terrylove.com/pdf/cst744s_footprint.pdf
Jamie can install these things pretty quickly.
He goes up stairs with the ADA Ultramax on his shoulder and hucks them around like they weigh nothing.
He's six foot four and weighs about 225.
Install kit for toilets
Notice that the bag of bolts includes four nuts and four washers.
Clear caulk
Seattle area website for TOTO, including the installation option
Looking inside the Drank tank.
The Eco Drake uses 1.28 gallons for the flush
Models would be
CST743E round
CST744E elongated
CST744EG CEFIONTECT
CST744EL ADA
Standard Drakes use 1.6 gallons
CST743S round
CST744S elongated
CST744SG CEFIONTECT
CST744SL ADA
Reader Review
Comments by readers
Hey Terry,
I successfully installed the toilet! It works like it should.
I sent out an email telling all my friends they no longer have to spend so much time in my guest bathroom re-flushing the toilet repeatedly to make a single square of tissue go down the drain!
Oh yeah - and you better believe I had a beer once I was done.
Thank you
Kelly
Jamie snugging up the large nut on the bottom of the tank.
Status
