Installing a toilet flange
Discussion in 'Toilet Forum discussions' started by kwhitt1017@yahoo.com, Jan 24, 2006.
  1. kwhitt1017@yahoo.com
    kwhitt1017@yahoo.com New Member
    Nov 25, 2005
    I am getting ready to place ceramic tile in my bathroom. Does the toilet flange sit on top of the tile or does it sit on the conc. board? If it sits on top of the tile does it have screwed into the tile?
    Thanks Much!! :)
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Unless it's cast iron it should be screwed down and sit on top of the tile...
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You will have to drill holes through the tile so the screws and go into the subfloor. I like stainless steel for this as they last much longer than others. Drill the holes with a slightly larger diameter than the screw to prevent breaking the tile when you sink the screws.
  5. jadnashua
    You can also put notches in the tile to line up with the holes in the flange so that you only need to go through the cbu and the subflooring when you screw it down. Much easier cutting those notches with the wetsaw than drilling if you are using something like a hard porcelain tile (unless you have access to diamond bits).
  6. kwhitt1017@yahoo.com
    Nov 25, 2005
    kwhitt1017
    Thanks all for your responses :)
Similar Threads: Installing toilet
Toilet Forum discussions Can hear other units flushing after installing new toilet Monday at 7:10 PM
Toilet Forum discussions Plumbing Hacks Video, installing a toilet with Terry Love Jun 28, 2016
Toilet Forum discussions Installing a toilet with 12" rough in Oct 15, 2014
Toilet Forum discussions Installing toilet on concrete slab problem Jun 28, 2014
Toilet Forum discussions Toilet leaks from bottom after installing new tank kit. Sep 28, 2013
