Installing a Toilet flange on porcelain tile floor
Discussion in 'Toilet Forum discussions' started by motonutz123, Jul 28, 2011.
  1. motonutz123
    motonutz123 New Member
    Jul 20, 2008
    New York
    I'm redoing my bathroom DIY except for the floor. I have a wooden subfloor that I will have porcelain tiles and backerboard installed on. Is it standard practice to mount the toilet flange on top of the tiles and drill holes through the tiles to the subfloor to fasten the flange or is a product like this a better choice http://www.set-rite.com/ ? Any suggestions or comments are appreciated. Thanks
  2. jadnashua
    Before we get too far, when you say wooden floor, is that dimmensional planks, or plywood? You can't put cbu on dimmensional wood planks...you need at least 1/2" ply on top of it. The planks move too much. The ply is much more stable, and tile need stabile! Make sure to install the cbu in a fresh mortar (thinset) bed and tape the seams as indicated in the instructions.
    The easiest way to handle the flange is to notch the tile before you lay it so you don't have to drill holes. You can drill, but you likely would need special bits (a diamond core bit probably works the best). You really do want the flange well attached to the subflooring. Check out www.johnbridge.com for help on tiling.
Similar Threads: Installing Toilet
Toilet Forum discussions Can hear other units flushing after installing new toilet Mar 20, 2017
Toilet Forum discussions Plumbing Hacks Video, installing a toilet with Terry Love Jun 28, 2016
Toilet Forum discussions Installing a toilet with 12" rough in Oct 15, 2014
Toilet Forum discussions Installing toilet on concrete slab problem Jun 28, 2014
Toilet Forum discussions Toilet leaks from bottom after installing new tank kit. Sep 28, 2013
