Installing a stop valve
Discussion in 'Toilet Forum discussions' started by Lawless, Apr 1, 2007.
  1. Lawless
    Lawless marketing coordinator
    Feb 10, 2007
    Portland, Oregon
    I'm installing a new toilet and need to install the stop valve between the supply and the tank. This is a new supply line that hasn't been cut yet. I just want to make sure I understand how to install the stop.
    1. Cut the copper pipe leaving enough room for the escutcheon and stop valve
    2. Slide the escutcheon, nut and ferrule over the pipe.
    3. Cover the pipe with some plumber's tape or pipe cement
    4. Slide stop valve on and tighten nut
    I'm unsure of the connection with the supply - is it really not going to leak? Seems sketchy to me, like there ought to be more....
    Angie
  2. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Actually, there's less......
    Based on step 4, I'm figuring you're using a compression (mounting to copper pipe) stop. There is no dope or tape used between the pipe and compression fitting. Clean metal to clean metal.
    Be sure to get a stop with the right size outlet to accept the braided stainlees flex connection to the toilet.
  4. jadnashua
    And, make sure you haved enough sticking out of the wall! Make sure that the cut end of that pipe is nice and square with no nicks or burrs.
  5. Lawless
    Feb 10, 2007
    Portland, Oregon
    Just say no to dope (and tape), leave enough pipe and don't overtighten - got it!
    NEW QUESTION:
    Re: the flange - I didn't tile right up around the hole for the drain pipe so I have to fill it in to get the flange to sit flush with the floor. The difference is 7/16". I have a piece of 1/4 ply that leaves me a hair higher than the floor. I had a bunch of Ditra left from my tile job and three layers of that leaves me a hair lower than the floor. I'm wondering which way to err. I don't want the bowl to have any chance of rocking...
  6. jadnashua
    Toilets are designed to fit on a flange that is mounted on TOP of the finished floor. Ideally, you would have tiled under it so you'd have a nice firm flat place to anchor it. As long as it doesn't sit more than the thickness of the flange above the finished floor, you should be fine.
Similar Threads: Installing stop
Toilet Forum discussions Installing a toto ultramax II Jan 31, 2017
Toilet Forum discussions TOTO THU9090R adapter for installing a Washlet on an Aquia Oct 13, 2016
Toilet Forum discussions Porcher Veneto: Need help installing Piston Jul 9, 2016
Toilet Forum discussions Plumbing Hacks Video, installing a toilet with Terry Love Jun 28, 2016
Toilet Forum discussions Need help installing 3x4 lead drain pipe on 3" steel pipe Mar 15, 2015
