Installing a sink tailpiece
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Titan7, Jul 6, 2010.
  1. Titan7
    Titan7 Member
    Feb 14, 2005
    I installed the sink about a year ago, looked under the sink and the tail piece looks like it has a tiny leak where it threads into the drain (the part that attaches to the bottom of the sink). So I took it off and the p-trap, cleaned everything off.
    I applied some oatey pipe compount #31226, grey, and then wrapped 3 times with telfon tape and reinstalled. Is this correct?
    Also why does the tape always bunch up, I put it on the treads clockwise. I assume there is nothing I put on the PVC P-trap treads on the other side of the p-trap.
    [​IMG][/IMG]
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    If your going to use both pipe dope and T-tape apply the tape first then the dope. Are you sure it's coming from the tail piece? It may be coming from the connection above it.
    John
  4. hj
    The tape bunches up because there is not enough room inside that connection for three layers of it.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I'll agree many times the leak is coming from the mack washer on the drain above.
    Make sure you check that carefully and if it is post back for a solution.
  6. Titan7
    Titan7 Member
    Feb 14, 2005
    It's not the Mack washer. There was some mineral deposits around the tailpiece connection, and it was a bit loose.
    So should I take this apart again and redo it?
  7. jimbo
    jimbo Plumber
    Those are very fine threads , and 3 wraps of tape could be too much. If it is together and not dripping,. let it be!!!!!!!
  8. Titan7
    Titan7 Member
    Feb 14, 2005
    Well, it does not appear to be dripping. I don't like the look of the extra white tape, looks sort or homeowener DIYer ; )
    If I decide to redo it, would you use paste or tape? If tape should I fold it in half and wrap once?
    The only pain is I have to disconnect the entire p-trap to get the tailpiece out ; (
  9. Titan7
    Titan7 Member
    Feb 14, 2005
  10. Terry
    Aug 17, 2004
    Just don't look. If it isn't leaking, quit beating yourself up. Now..........where's the beer.
    I like dope on those threads. It hides better.
  11. hj
    If the tailpiece is tight, and you just don't like the look of the tape, unpeel the excess which is showing. It is not doing anything anyway.
Similar Threads: Installing sink
Plumbing Forum, Professional & DIY Advice Installing a sink for toddler Nov 22, 2016
Plumbing Forum, Professional & DIY Advice Need help installing utility sink. Sep 7, 2016
Plumbing Forum, Professional & DIY Advice Installing kitchen sink drain Jul 31, 2016
Plumbing Forum, Professional & DIY Advice Installing under sink filtration system May 26, 2016
Plumbing Forum, Professional & DIY Advice Need help with installing laundry sink plumbing Apr 24, 2016
