Installing a Shower Panel
Discussion in 'Shower & Bathtub Forum & Blog' started by PTJ, Feb 1, 2012.
  1. PTJ
    PTJ New Member
    Feb 1, 2012
    Central NJ
    First plumbing forum post, so here goes. I'm currently remodeling a bathroom and plan on installing a shower panel (Lyria Thermostatic from SigHardware, 1/2" FIP). for the hot and cold water supply to the panel, what plumbing pipes/parts should be used? By googling, I see that drop ear elbows and 1/2" IPS piping is suggested to bring the plumbing past the tile. My concern is having full/continuous house water pressure on threaded connections behind the wall. Is this a concern?, maybe I'm just brainwashed to think all pressurized plumbing hidden behind wall/cement board is to be soldered. thx
  2. jadnashua
    A properly made threaded connection is as watertight as any other method. Depending on what's on the panel, since it likely has both hot and cold connections, you can't have threaded connections on both ends, since there's no way to rotate the panel. There are some threaded connections that would work, though. The ID of the pipe is the same whether it is a threaded nipple or a soldered pipe connection. What's best for this situation would be determined by exactly how the thing was designed, and can't see that.
  4. PTJ
    PTJ New Member
    Feb 1, 2012
    Central NJ
    Hi Jim, The link for the panel is http://www.signaturehardware.com/product17066, as a fyi. The panel water lines are 2 flexible SS lines, the panel connection to the water supply from the wall would be 1/2" FPT (panel) to 1/2" MPT (supply). Thanks for the comment on hidden threaded connection. Paul
  5. jadnashua
    See if you can find the manufactuer's website and point to the installation instructions...this would give more useful install info. Looks nice, no experience with that brand, so can't say much of anything with that regard.
Similar Threads: Installing Shower
Shower & Bathtub Forum & Blog Demo'd Fiberglass Shower & Installing New Tile Shower But I Have Questions??? Saturday at 2:13 PM
Shower & Bathtub Forum & Blog Installing code-compliant 2 handle shower faucet Jun 20, 2016
Shower & Bathtub Forum & Blog Installing Kohler Rite-Temp Bath & Shower Valve K304 + Mastershower 2 or 3-way Transfer Valve K728 Jun 5, 2016
Shower & Bathtub Forum & Blog Need help installing new shower faucet Feb 5, 2015
Shower & Bathtub Forum & Blog Installing a fan inside your steam shower: Good idea or bad Jan 27, 2015
