Installing a no caulk shower drain
Discussion in 'Shower & Bathtub Forum & Blog' started by JerryM, Nov 3, 2005.
  1. JerryM
    JerryM New Member
    Nov 3, 2005
    Seattle Washington
    :) Hello everyone. I'm installing a no caulk shower drain for the first time and I'm looking for instructions on how to do it correctly. The one that I am replacing is leaking somewhere and is causing serious damage to the room downstairs. I know that I already have to replace the damaged drywall below so gaining access underneath is not an issue. Also, when looking at the drain line it doesn't seem to be supported well enough around the bottom of the stall (one-piece fiberglass) and right now it seems to me that the weight of someone using it in the future will cause this to happen again.
    Do I use ABS glue in fitting the new drain to the drain line? Should I strap the line? Any ideas?
    Thanks bunches,
    JerryM
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    ABS (solvent (aka "glue") can only be used to join ABS pipe to ABS fittings. (The same rule applies to PVC solvent) Your drain fitting should have directions for installation enclosed. The shower stall rests all of its weight on the floor, usually with mortar spotted beneath to prevent sagging or flexing under heavy weight, and is nailed or screwed to the studs at the top and down the edges to keep it from shifting. The drain does not support any weight. The pipe needs to be cut to the correct height as will be indicated in the drain fitting instructions. Follow the instructions carefully and you shouldn't have a problem.
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    the hard part
    the hard part of the job is to install this
    drain after the shower has already been installed
    from underneath
    it can be pretty mean , I mean very mean----
    to get the nut to tighten down
    enough to the old shower base when you are standing on your
    tippey --toes on a ladder trying to move a 4 inch nut
    and squeeze out the acess putty ...
    Remember -if you dont squeeze out most of the putty it will
    not tighten down properly and the flange will loosen up over time
    normally this is done on the rough inn
    with a large 24 inch Rigid wrench
    which you cant use in this situatioin...
    probably a hammer and small chisel to tap the nut and
    tighten it into place...will work best...
    usually it takes someone upstairs standing on the flange
    to keep it from moveing on you (your wife)
    Now,
    I know I am gonna get some rave comments from my astute
    audiance on this advice ...but here goes anyway...
    In a few of my more mean situations, I opted to use clear
    water proof silicone instead of putty on the lip of that
    flange.....if everything is clean and dry it works great
    a very healthy amount works best , cause it all wipes off.
    it squeezes out good, the nut tightens down great
    all the way down to the base without the usual troubles like with putty.
    and
    it makes a %100 water proof seal to both the lip on the shower base and it also makes almost a PERNAMENT seal on the bottom side of the
    base around the nut and gasket . Just clean it up with your finger
    on both the top and bottom...,.
    Note.....the only down side I have ever found about doing this is
    it will never unthread off again....without a hammer and chisel..
    its on there to stay.....
    but you were not planning on doing this over again, right??.
    now on the top with the no-caluk clamping down ring,
    I suggest after you clamp that neopreme ring down tight to the
    pvc pipe , you also put a bead of silicone on top of all that
    for extra measure and give it slope into
    the drian .........that I do on every job for my own
    satisfactioin
    then you absolutely know it is %100 water tight on that second
    floor shower
    support it with bailing wire or something
    if you need to after you are done ,
    thats all secondary--- any kind of glue that is compatabel with
    the brand of plastic pipe you are useing will work,,,
    just be sure to get the drain tight,
    or you will do it again some day.
    have lots of fun......
  5. Toddtsch
    Toddtsch New Member
    Mar 29, 2009
    Purchased PlumBest No Caulk shower stall Drain D40-140. Did not come with installation instructions. It comes with wrench included. After installation should the wrench be removed? If so, how? Should silicone be used to seal?
  6. waterslaw
    waterslaw New Member
    Mar 30, 2009
    Being Retired is hard work
    South Carolina
    First time posting here.
    I just bought the same D40-140 and is has no instructions. I guess "Real Plumbers" know from experience how it goes in.
    The "Grate" (with Blue plastic film) on the top pops off, allowing access to the wrench and to control how far up from underneath the drain pipe comes. I had to search the Net for hours before I found a mention of instruction.
    I used Plumbers Putty made into a snake and wrapped it around under the lip of the drain and then cinched it down through the shower pan with a BIG pair of adjustable end wrench. I waited until it oozed out and cinched again.
    It said No Caulk, but I prefer to be extra safe.
    Hope this helps.:)
  7. Phil Clemence
    Phil Clemence New Member
    Jul 12, 2008
    By the "wrench " i think you mean the steel piece witht the slot for tightening the 'castle' nut. Yes, you can throw that away after you are done. I prefer to use two screwdrivers in an 'X' to tighten with, as i dropped the 'wrench' into a trap before and has to fish it out :D Using crossed screwdrivers also allows the pipe to be a bit higher into the drain, making it unlikely that the pipe top could ever get below the top of the black gasket, even with flexing of base/floor.
    Strapping is a good idea but make sure you do not put upward pressure on the underside of the pan. That can happen if you lock the pipe into the drain assembly and then strap the pipe, so it's best to strap the drain at the height you want and then lock the gasket down in the drain.
    As Master Plumber Mark suggested ... make a smooth silicone bead (100% silicone with anti-mildew agent, typically called "Kitchen and Bath") around the inside of the drain (clear looks best to me), covering the castle nut and with a slope down to meet the edge of the pipe. That keeps the drain nice and clean (otherwise there will be a little ring of water standing around the pipe - that leads to yucky slime). Have some paper towels around for wiping excess silicone off your fingers :D Keep the silicone away from the very top edge of the drain, as that is where the grate snaps in.
  8. piper2
    piper2 New Member
    Apr 4, 2009
    no caulk drain
    I have used a compression type shower drain on 2 showers that were roughed in thru concrete and they seemed to work very well, had no leaks and as to date no leaks apx. 3 yrs. since install. Hope this helps
  9. thebigsee
    thebigsee DIY Member
    Sep 24, 2009
    Southern California
    This thread has been dormant awhile but I just want to point out in the ongoing "putty vs. silicone" debate that at least with no-calk shower drains, both of the mainstream manufacturers (Oatey and Sioux Chief) specify using SILICONE under the flange, not putty. As such, the debate should be moot if people want to follow what the manufacturers suggest -- use silicone!
  10. toolpro
    toolpro New Member
    Nov 3, 2010
    folsom, ca
  11. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Do they sell these drains with a 5" grate top?
    JW
  12. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Found a No-Chaulk Shower Drain at Rona for $8.99. Made in China. No box. No Bag. No instructions. Not even a brand name on the sucker.
    There is a S boxed with a rectangle on the grate along side a CSA logo. So I'm guessing it's approved.
  13. jadnashua
    I wonder why John expects an answer from a 3-year old post? Trying to get his post counts up?
  14. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Went looking for more options in the No Chaulk shower drains. Found a few more.
    Of the four drains I have now only one is designed with weep holes... I think that will be the one I use.
Similar Threads: Installing caulk
Shower & Bathtub Forum & Blog Demo'd Fiberglass Shower & Installing New Tile Shower But I Have Questions??? Yesterday at 2:13 PM
Shower & Bathtub Forum & Blog Installing a Panasonic bathroom exhaust fan in a condo Feb 9, 2017
Shower & Bathtub Forum & Blog Installing a washer drain 1 ft from main stack - is vent necessary? Jul 17, 2016
Shower & Bathtub Forum & Blog Installing code-compliant 2 handle shower faucet Jun 20, 2016
Shower & Bathtub Forum & Blog Installing Kohler Rite-Temp Bath & Shower Valve K304 + Mastershower 2 or 3-way Transfer Valve K728 Jun 5, 2016
