Installing a neoprene sleeve banded coupling - the easy way!
McG
CT, RI
Okay fellas (and gals) my finger tips are raw from trying to unroll the black rubber sleeve of a banded coupling. I got one end on and have now to roll the cuff onto the joining 2" PVC pipe. I am working in a very cramped and confined space - lath and plaster behind, a stud an inch to the left - but come on; It shouldn't be this difficult! I have tried vaseline and that didn't seem to help at all. There must be some trick to this. It looks so neat and easy in the picture books. Does anyone have a trick for unrolling these things. Condoms are easier to install.
Mike Swearingen
On Albemarle Sound In Northeastern NC
www.albemarle-realty.com
If that is a no-hub (aka Mission) coupling with a neoprene sleeve inside a stainless steel sleeve in good condition, there should be nothing to "unroll" and it should slide on (maybe with a little lube). You can try heating it with a hair dryer.
Personally, I would just get another one that will slide on.
Mike
McG
CT, RI
Neoprene Sleeve
Mike, it is a hub fitting with a corrugated paper outer sleeve. The sleeve has four metal bands that are tightened with a ratchet I don't know the manufacturer or the style of banded coupling the one I'm currently working with is. I only know of one other banded coupling which does not roll up but that would be impossible to install because there is not enough clearance. Because the one I have rolls up on itself, I am able to realign the pipe which is locked in place by couplings above and below the joint. Perhaps the Mission style sleeve is yet another type that goes on loosely can be slipped up or down as necessary, positioned and then tightened. That does sound like an ideal coupling for my circumstances here. I will ask at my local plumbing supply house if they have another style that may work for me. I would like to use the one I have and it would work if I could only unroll it.
GrumpyPlumber
Licensed Grump
Licensed Grump
Lube is the last thing you want on this, you'll never be able to grip the rubber.
I think you meant to say "corrugated steele sleeve" (not paper..I hope)
Roll the rubber down before you put it on, slip it over whichever pipe has any play in it, then roll it over the pipe after it's on one side.
sleeve
remember, you have an incentive to get the condum on quickly. Stand the pipe or fitting on the floor. Insert one end into the coupling, after sliding the band back off the neoprene sleeve. Then push down with your hand while guiding the neoprene back over the other half. Start on one side and work both ways at the same time to the other side
