Installing a Dryer 30 Amp power cord, 120/240 volt. what gauge wire?
Discussion in 'Electrical Forum discussion & Blog' started by 87vertgt, Sep 18, 2009.
  1. 87vertgt
    87vertgt New Member
    Sep 10, 2009
    Chicago,IL
    10 gauge? talk to me boyz
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    All dryer cords are #10.
  4. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Dryer = #10 wire
  5. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    I would run 500kcmil just to play it safe with voltage drop. M1 cable would be a better choice
  6. r_2016
    r_2016 New Member
    May 25, 2007
    # 10 wire will do. Fyi, I think that #10 wire is orange.
  7. Speedy Petey
    Jun 16, 2007
    NY State, USA
    I've never seen an orange dryer cord.
    Besides, I think the OP forgot all about this thread. I would be nice if he came back to explain what the heck he is asking about.
  8. hj
    wire
    #10 wire is WHATEVER color you decide to buy. The Dryer "cord/pigtail" will be red, white, black, and green with a black covering over it.
  9. Ford2001
    Ford2001 New Member
    Sep 11, 2009
    property care taker
    Manchester, Vermont
    Just make sure the receptacle outlet will except the male end of the
    dryer cord.
    So are you going to use a 3-wire or 4-wire dryer cord set.
    Installing a 4-wire dryer cord set can be a little tricky.
    With a 3-wire, grounding of the dryer frame is done thru the
    neutral/grounded conductor of the dryer cord
    With a 4-wire, grounding of the dryer frame is done thru the ground
    conductor of the dryer cord.
    And if not sure how to do this properly, post back, there some good
    guy here, that will walk you thru it.
  10. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    My covering is gray ...
Similar Threads: Installing Dryer
Electrical Forum discussion & Blog Installing an AFCI breaker Jan 5, 2017
Electrical Forum discussion & Blog Homeowner installing electric to hot tub Nov 30, 2014
Electrical Forum discussion & Blog Installing Garbage Disposer electrical Jun 18, 2014
Electrical Forum discussion & Blog What to do with wires when installing light switches/plugs Sep 9, 2013
Electrical Forum discussion & Blog Grease on new Siemens circ. breaker contacts - need to wipe out before installing? Aug 13, 2013
