Installing a Big Box Store Electric Base Board Heater
Discussion in 'Electrical Forum discussion & Blog' started by 87vertgt, Oct 3, 2009.
  1. 87vertgt
    87vertgt New Member
    Sep 10, 2009
    Chicago,IL
    Amps : 6.25 A
    Assembled Depth (In Inches) : 2.5 in
    Assembled Height (In Inches) : 6.75 in
    Assembled Weight (In LBS) : 13.60 lb
    Assembled Width (In Inches) : 72 in
    BTU Heat Rating : 5118 Btu/h
    Color / Finish : White
    Depth : 2.5 in
    Energy Star Compliant : No
    Fuel Type : Electric
    Heating Area : 150 ft²
    Height : 6.75 in
    Maximum Wattage : 1500 W
    Thermostat : No
    Vented : Yes
    Voltage : 240 V
    I am guessing to run a 10 gauge wire. 30 amp fuse? can I run two of these on 1 line?
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    WHY????
    Why not #12 on a 20A?
    Absolutely. You can even put two on the same 20A circuit.
  4. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    You can run 14/2 on a 15A breaker and have no problems and be code compliant.
Similar Threads: Installing Store
Electrical Forum discussion & Blog Installing an AFCI breaker Jan 5, 2017
Electrical Forum discussion & Blog Homeowner installing electric to hot tub Nov 30, 2014
Electrical Forum discussion & Blog Installing Garbage Disposer electrical Jun 18, 2014
Electrical Forum discussion & Blog What to do with wires when installing light switches/plugs Sep 9, 2013
Electrical Forum discussion & Blog Grease on new Siemens circ. breaker contacts - need to wipe out before installing? Aug 13, 2013
