Installing a 4 gang new work box--install another stud to support it?
Discussion in 'Electrical Forum discussion & Blog' started by ironspider, Mar 1, 2010.
  1. ironspider
    ironspider Member
    Jul 26, 2008
    Michigan
    Hello all,
    I need to install a 4 gang blue electrical box (see picture) at the bottom of my basement stairs and the box has two holes on a plastic plate on one end (the attached picture has like 5 but mine only has 2) and the two nails on the other end. I feel like if I just nail the nails into the stud the box might be kind of "wobbly" (whereas a single box would be on there strong as hell). So my question is, with "longer" boxes like this, how do you add extra support? Would you nail the little lip through the two holes to the existing stud and then add another stud (well the stud would go in first obviously!) and nail the two angle nails to that added stud? Or something else? Or are the nails strong enough to hold it?
  2. iminaquagmire
    iminaquagmire DIY Senior Member
    Dec 16, 2007
    FF/EMT
    You have the right idea.
    [​IMG]
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Also worth noting that all NM cable must be secured within 12" of the box. :p
  5. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    There has been a design change and those boxes now come with a support that is screwed to the back and attaches to the stud that it's nailed to.
    It's a great improvement because backing can be a pain to install.
    Without backing, after the drywall is installed, the tab on the right side of the box will keep the box from pulling out. Install the outside switch first and don't push too hard on the others.
Similar Threads: Installing gang
Electrical Forum discussion & Blog Installing an AFCI breaker Jan 5, 2017
Electrical Forum discussion & Blog Homeowner installing electric to hot tub Nov 30, 2014
Electrical Forum discussion & Blog Installing Garbage Disposer electrical Jun 18, 2014
Electrical Forum discussion & Blog What to do with wires when installing light switches/plugs Sep 9, 2013
Electrical Forum discussion & Blog Grease on new Siemens circ. breaker contacts - need to wipe out before installing? Aug 13, 2013
