Installed 240v Dryer, used 10 gauge wire, 20 amp breaker-breakers flicking off
Discussion in 'Electrical Forum discussion & Blog' started by 87vertgt, Oct 16, 2009.
  1. 87vertgt
    87vertgt New Member
    Sep 10, 2009
    Chicago,IL
    What did we do wrong? also the breaker gets warm too...
    thanx gents :)
  2. 87vertgt
    87vertgt New Member
    Sep 10, 2009
    Chicago,IL
    correction used a 30 amp double breaker
  4. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Well, saying the breaker "keeps flicking off" is not much of a description.
    How long before it trips?
    Is the dryer new or old?
    Did you wire it right?
    You say it gets warm. Like hot? Or warm that you can keep your hand on it?
  5. jadnashua
    If the run to the dryer is excessively long, you might want to upsize the wire, too. Probably not an issue. If you have a multimeter, you could check the voltage at the panel, then again at the dryer with it running. Don't do this if you aren't comfortable and knowledgable about working on power. If there is a significant voltage drop, then you have a bad connection somewhere or the wire is undersized (shouldn't be, though). Could be in the plug, or cord, or maybe even at the panel. Does the breaker get warm, too? Could have a bus bar problem or a bad breaker.
  6. 87vertgt
    87vertgt New Member
    Sep 10, 2009
    Chicago,IL
    thanx for the response gents
    when I say "flicking off" i mean the breaker is turning off.
    The dryer is new.
    I didnt wire it. I electrian did.
    The breaker gets warm, not hot.
    The cord is new. The wire is new. I am gonna replace the new breaker with another new one.
    Whats a Bus bar?
  7. Ian Gills
    Jul 24, 2007
    USA
    Call the electrician back.
    I hope the electrician wired the receptacle properly. If the neutral and one of the hots is reversed, you could be running 240 volts to parts that are 120 volt rated.
    As an aside, I also hope he remembered to remove the grounding jumper in the dryer if this is a new four-wire set up.
    If he made both of these mistakes, fire him.
  8. hj
    dryer
    IF he connected a hot lead to the neutral terminal, AND did not remove the jumper, the customer will probably FRY before the electician is FYRed (sic).
  9. Ian Gills
    Jul 24, 2007
    USA
    Or with a four wire set up, it would trip the breaker.
    Absolutely anything could be wrong with it. Call the electrician back.
    Only the English should play with 240 volts.
    While inventors in many countries contributed to electric power technology, the U.S. was way out front in putting that technology to practical use. In the early days, lower voltages were the most practical for electric lights-- higher voltages burned out the bulbs. So the hundreds of power plants built in the U.S. prior to 1900 adopted 110 volts (or 115 or 120 volts) as their de facto standard.
    Trouble was, power transmission at higher voltages was more efficient-- and you didn't have to use so much copper in the wires. By the time most European countries got around to making big time investments in electricity, the engineers had figured out how to make 220-volt bulbs that wouldn't burn out so fast. So, starting in Germany around the turn of the century, they adopted the 220-volt (or 230- or 240-volt) standard. But the U.S. stayed with 110 volts (today it's officially 120 volts) because it had such a big installed base of 110-volt equipment.
  10. Speedy Petey
    Jun 16, 2007
    NY State, USA
    The ONLY answer.
  11. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    What about the Italians & Germans & French & all those other folks?
  12. Cass
    Cass Plumber
    Nov 12, 2005
    What is the brand of the main pannel?
    It doesn't happen to be Federal Pacific does it?
    Call the electrician back...
  13. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    You shall not disconnect my hot tub from 240v !! :p
    Nor my HW heater, dryer, stove, AC, radiant floor heat.........
  14. hj
    ian
    quote; Trouble was, power transmission at higher voltages was more efficient-- and you didn't have to use so much copper in the wires.
    You did not mention that at the higher voltages electromagnetic forces on the center of large conductors becomes a detriment, so "hollow" wires are more efficient.
Similar Threads: Installed 240v
Electrical Forum discussion & Blog Chasing short on newly installed light circuit (also newly drywalled) Jul 11, 2011
Electrical Forum discussion & Blog Installed new low voltage recessed lights - now switch hums Apr 12, 2008
Electrical Forum discussion & Blog New fan installed has one very dim halogen bulb Sep 22, 2007
Electrical Forum discussion & Blog Oven/Microwave installed on same wall as service panel Jul 23, 2007
Electrical Forum discussion & Blog How To Wire a Square D QO220GFI 240v, 20-amp Double Pole Breaker Monday at 4:13 PM
