Installation of softener with well
Discussion in 'Water Softener Forum, problems, installation and r' started by Larry_T, Oct 21, 2009.
  1. Larry_T
    Larry_T New Member
    Nov 25, 2008
    Hi -
    Two questions regarding installation of a softener with a private well:
    1) We have slight sediment in the water after hard rains. We were going to install a whole house filter at the same time as installing softener, but reading posts here do I understand correctly that a whole house filter is not recommended if we install a softener?
    2) The way the utility room is set up in our basement, it looks like space for a softener is _before_ the pressure tank. Is this the correct location? Somehow, it seems that the softener would be after the pressure tank.
    Thanks.
    Giles
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Is your well a dug well or drilled?
    How much is your idea of slight ?
  4. Larry_T
    Larry_T New Member
    Nov 25, 2008
    We have a drilled well, about 300'.
    Sometimes, a day or two after heavy rains, we'll notice a slight discoloration of the water in the toilet bowl or bathtub. By slight, I mean you can just barely tell that the water isn't perfectly clear. It clears up within a day or two.
  5. mattbee24
    mattbee24 In the Trades
    Mar 29, 2007
    Salesman and Purchasing Agent for a wholesale plum
    Fremont, OH
    The softener goes after the pressure tank.
  6. Gary Slusser
    Retired
    And depending on what brand control valve you have, no prefilter. About the only control valves that need a prefilter are the big box store brands and Kinetico.
  7. Larry_T
    Larry_T New Member
    Nov 25, 2008
    Thanks very much. That's the info I needed.
  8. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Giles, have you had the water tested? Just wondering why you think you need a softener.
Similar Threads: Installation softener
Water Softener Forum, problems, installation and r Water softener installation: plumbing questions Dec 29, 2015
Water Softener Forum, problems, installation and r Softener Installation - Water Line in a bad place Jun 8, 2014
Water Softener Forum, problems, installation and r Softener sizing and installation questions Jun 2, 2014
Water Softener Forum, problems, installation and r orange county: Fleck Water Softener distributer/ installation Oct 24, 2013
Water Softener Forum, problems, installation and r Need Advice on water softener Installation Jul 3, 2013
