Installation Instructions for Toto Guinevere and Soiree?
Discussion in 'Toilet Forum discussions' started by Sunny Bunny, Jan 17, 2008.
  1. Sunny Bunny
    Sunny Bunny New Member
    Jan 11, 2008
    [​IMG]
    Toto Guinevere toilet.
    I've been searching for installation instructions for the Guinevere and Soiree toilet and can't find any. Are they similar to the those for the Carlyle series (MS904114 or MS884114 series)?
    Before I order the Guinevere I want to make sure that my water supply line will work with the wide skirt or if I will have to have it moved over by a plumber. Looking at the specs, which was all I could find, it looks like I might have to have the water line moved since it indicates the line should be 8" from the center of the toilet. How close can the supply line actually be?
    Also, I noticed a "special note" on the Toto website for the Carlyle, which said "Water supply rough-in is wider than standard 5 1/2" rough-in. Consult your builder or contractor." Does anyone know if this also applies to the Guinevere? It wasn't mentioned but it seems that complete information re: the Guinevere is lacking.
    So, if folks out there know answers to any of these questions, I sure would be grateful. Thank you!:)
  2. Terry
    Aug 17, 2004
    The Gunivere and the Soiree work with a water supply 5-1/2" to the left.
    The installation is very much like the Carlyle installation. (The Carlyle needs 7")
    You install the Unifit to the flange, and drop the bowl over it.
    [​IMG]
    If it's a new installation, there may be a plug for the flange.
    [​IMG]
    Knock out the flange
    [​IMG]
    Ready to drill the floor and set the Unifit with a wax seal.
    [​IMG]
    Installed and ready to be caulked at the floor.
  4. Sunny Bunny
    Jan 11, 2008
    Terry, Thanks for the advice!
    Terry, Thanks for the advice!:)
  5. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    The unifit to flange connection requires a wax ring seal which Terry's excellent picture does not show.
  6. Tenderpaw
    Tenderpaw New Member
    Jan 12, 2008
    Washington
    Terry- will the Carrollton or the Vespin also work with the valve that way? My valve is about 7 inches from the center line and 7 inches off of the floor? Will it work with these toilets?
    Dave
  7. Terry
    Aug 17, 2004
    The Carrollton and the Vespin will work with the valve at 7" center to center.
    The TOTO Guinevere and the TOTO Soiree.
    These are two of what I consider the best of what TOTO has. In the last two years, I've sold 121 of these.
    Most are in high end homes, but sometimes just older homes in Seattle.
    They look great and flush well.
    The best features are the comfort height bowl, the bowl is 16-1/8" before you add for the nice slow closing seat.
    The skirted base, which makes for easier cleaning.
    When replacing bowls, this is nice, it will cover almost any footprint that has been left on the floor.
    Since the back of the bowl is slimmer then the Carlyle, you only need 5-1/2" to the left of center for the shutoff.
    Since most plumber rough-in at 6" or more, they will fit almost anywhere.
    You also have the option of using the standard 12" rough-in that comes with the toilet, or installing with a 10" or 14" Unifit.
    This is great for both older homes, with 14" rough-in, (Many homes in the 20's had 14") or homes with the rough-in too close to the wall.
    Parts are easy to get, we use the same basic parts in all of the TOTO toilets, so if you have a part for one, you can pretty much fix the entire lineup.
    Real customers are reporting back that they love the toilets.
    I have one customer, a neigbor of Bill Gates in Medina, that started with two of the Guinevere, and when he found that he liked them, he ordered three more for a total of five.
    Steve Balmer went with the Neorest600 in his master bath, it also has a adapter like the unifit, Sanagloss and double cyclone rinse, but with the added feature of the Washlet seat and automatic functions.
    I hear back that he's thinking of getting more of them.
    The bread and butter of the TOTO line is the Drake and the Ultramax, and the top of the line is the Guinevere and the Soiree. Unless you are thinking of the Neorest lineup. Off all the brands I'm selling, the Toto has the least problems and the highest customer satisfaction. I sell all brands, and we do about 2,000 toilets a year.
    We also see what people are replacing and what they think of those.
    Most of the business is made of repeat customers and referrals.
    Some brands sell themselves, and some are installed for a short while, until we come to pull them out.
    Terry Love
    December 4, 2009
  8. Sunny Bunny
    Jan 11, 2008
    Is it a problem if the water supply is not 5.5" away? I mean what if it is closer, even a lot closer? What would happen? Also, does the supply have to come out of the wal? Currently my pipe come up through our floor. Thanks!
  9. jadnashua
  10. Terry
    Aug 17, 2004
    [​IMG]
    TOTO Soiree pedestal lav, faucet and toilet suite
  11. Terry
    Aug 17, 2004
    When installing these, I like to make sure the bowl is flat to the floor before tightening the back bolts.
    Depending on the floor, that may mean shims.
    If you shim the bowl, shim from the back, pinning the front of the bowl to the floor.
    Once there is no movement, then you can snug down the back bolts.
    I like using Clear PolySeamSeal, water based to caulk around the bowl.
    It goes on white and dries clear.
  12. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    A toilet does not care where the water comes from. Through the wall is the usual, but sometimes through the floor. FWIW, mine comes through the floor. I'd change it if it didn't require too much demolition of the basement ceiling, but it works just fine. Most general instructions for location is 8" to the left of the toilet. Directly behind might present a problem. Supply lines come in various lengths, so you can easily fit the line to the toilet.
    [​IMG]
Similar Threads: Installation Instructions
Toilet Forum discussions TSU24A fill valve installation instructions? Apr 13, 2010
Toilet Forum discussions Complete Toto Aquia installation instructions written by Jamie Love Apr 18, 2007
Toilet Forum discussions Installation tips for the neophyte Feb 6, 2017
Toilet Forum discussions Parts needed for TOTO CST244EF#01 Entrada installation? Dec 13, 2016
Toilet Forum discussions Requesting help with Toto Entrada Tank installation problem May 15, 2016
